I have a Korg Nano Kontrol 2 Midi Controller.
Started to play to make a custom mapping but can't find what I want.
The flow to make a custom mapping works. I was able to map the Master output and Headphones level but can't find how to map a slider to a deck fader.
My controller has many faders; I just want my first fader as fader for deck 1, second fader for deck 2.
Found the command 'level' but it is generic and cannot be linked to a specific deck.
I also want 1 play button for deck 1 and another play button for deck 2.
The default mapping is 1 play button and with up/down buttons I can select the deck.
Any help or examples appreciated!
Posted Wed 21 May 25 @ 7:25 pm
Use deck 1 level or deck 2 play or deck left loop e.t.c.
Posted Wed 21 May 25 @ 9:06 pm
Thanks! That works great. Noticed 1 problem with PITCH slider.
If I map a slider to deck 1 PITCH it works strange.
With the slider down (must be PITCH - Minimum) is it Pitch + Maximum and opposite, withe slider fully up, the PITCH in VDJ is minimum. Any change to change this behaviour?
Posted Thu 22 May 25 @ 4:40 pm
param_invert & deck 1 pitch
Posted Thu 22 May 25 @ 4:44 pm
@DJDAD thank you very much!
It goes the right direction, the pitch/fader and my progress ;-) due to your help! Thanks
One more thing made a 'deck 1 loop' and 'deck 2 loop' button this works.
Made also a button 'loop_double' and 'loop_half' but these buttons only work for deck 1.
Is there a way to double or half the loop from the active deck?
Posted Thu 22 May 25 @ 5:52 pm
deck default loop_double
Posted Thu 22 May 25 @ 7:19 pm
Thanks everyone for the wonderfull support!
Posted Thu 22 May 25 @ 7:37 pm
