Im using using pioneer XDJ-RX3. When im using virtual dj but it's playing on my controller under the rekordbo skin , also when I m trying to use the samplers it just playing through my headset not from speaker. Please let me know what's wrong. Tnx
Posted 4 days ago @ 1:51 am
I have the same problem. If I switch "XDJRX3-MixerMode" from MIDI to hardware, it works, but then all gain adjustments disappear.
https://www.virtualdj.com/manuals/hardware/pioneer/xdjrx3/mode/index.html
I haven't found a solution for how to do it in MIDI mode.
I hope someone else has a solution!
Posted 8 hours ago
Setting SamplerOutput is at 0 ?
If so, it means Sampler is output to "All Decks", but i guess you need to make sure some Channel faders need to be up to reach Master.
Posted 2 hours ago
