Hello guys...
I just added my microphone to VDJ and since that I hear so many annoying crackling sounds in VDJ. I dont know what I did wrong. The goal of mine and a friend is to play our Songs on stage with Autotune while VDJ is running in the background... so its a must that the microphone is connected. Do you got any advices what I can do? My Computer is very good when its about performance and in no other DAW i got crackling sounds, even when a few plugins are running at the same time.
Do you know what I can do?
Much thanks
Lukas
Much thanks
Lukas
Posted Sun 16 Mar 25 @ 8:30 am
What's the make and model of the microphone? How is it connected to (through) VDJ?
What audio interface are you using? Are you using a Mac or a PC?
If you're just using VDJ to play backing tracks, there's no need to send the mic signal through VDJ.
Posted Sun 16 Mar 25 @ 10:29 am
Its a Neumann TLM Microphone, and I payed 700 for it.
Im using the Focusrite Solo Interface of the third generation
I not only want play backing tracks... I want to route Autotune and other effects from Fl Studio to Virtual DJ cause Im going to be a DJ for my artist friend. Do you know how I can route effects from FL Studio to VDJ?
Posted Wed 19 Mar 25 @ 11:03 am
You need to check the latency setting for the Focusrite, and increase the buffer size as required.
VirtualDJ can host VST plugins itself.
Posted Wed 19 Mar 25 @ 11:34 am
I know it can host VST Plugins, but when I try to sing or rap over autotune efx in VDJ it wont work. And I heard from many sources that its much better too route the effects from another DAW
Posted Wed 19 Mar 25 @ 1:01 pm
hello there , i have been facing issue with some crackling sound in Virtual dj latest version while playing musicany solution to it
Laptop I am using is
Acer Nitro V15 with 16 gb ram , 6 gb nvidia 3050 graphic card + intel grapic card
Posted 6 hours ago
https://virtualdj.com/wiki/PC%20Optimize.html
Posted 2 hours ago
