Hi, i have a second hand vestax VCI-400 works very good with VDJ. Even these days years later is a awesome quality controller . is updatet to the last firware version, All works ok except :
But I would like to fix this:
In vinyl mode the jog only works if I hold down the button Vinyl , is a firmware thing or map problem ? If I map the vinyl function to another button it works fine.
Is it possible to map the jog so that when the song is not playing I can seek fast throughout the track with shift + jog?
Thanks
Thanks
Posted Tue 29 Oct 24 @ 6:32 pm
Set it to vinyl in settings.
Posted Wed 30 Oct 24 @ 7:13 am
that's it but this does the same thing . Vinyl mode only works if hold down vinyl button
Posted Wed 30 Oct 24 @ 12:04 pm
Open the mapping page, and touch the jog.
What do you see on the right side of the window ?
Do you see the "JOG_TOUCH" key listed ?
If yes, what's the mapping of it ? It should be "touchwheel_touch"
Posted Wed 30 Oct 24 @ 2:08 pm
Yes is ok configured as you mention, but the problem is ... i only sractch if the vinyl button is hold pressed i post a video:
https://youtube.com/shorts/pPf5id5Hdn8?feature=share
Posted Wed 30 Oct 24 @ 4:59 pm
Are you using a "custom" definition for your VCI-400 ?
Check your VDJ HomeFolder /Devices folder and see if there is a VCI 400 related file there.
Perhaps you have flashed some firmware version instead of the original ? Your VCI is 400 or 400SE or some other ?
Posted Wed 30 Oct 24 @ 5:26 pm
no vci400 -related files in device folder . Only a file controllers.dat
The firmware is the last available 2.03 these are the changes are relation with this? there are a 2.0 firmware also in the web , is a good idea downgrade?
These are the main changes in the new firmware to run correctly with Serato DJ.
MIDI firmware (version 2.03)
- The CUe LEDs for Deck C/D are now controlled by the firmware, not MIDI.
So you can switch it on and off even when no computer is connected.
- If you put the mode switches on the front in the middle position, they light up
Transport certificates are no longer green, as was the case in previous versions.
- The color of the transport buttons can now be controlled by MIDI CC notes.
CC-Note 65-127 sets the LEDs to red/yellow, CC-Note 1-64 sets the LEDs to green.
CC grade zero she changes.
- The jog wheel note is sent independently of the vinyl button.
- The vinyl button lighting is no longer controlled by the firmware, but can
controlled by MIDI.
- The shift button does not light up when pressed.
controlled by MIDI.
Posted Wed 30 Oct 24 @ 6:17 pm
Will send u a file to test via email
the file i sent you to test only has a possible fix for the VINYL button, but the firmware 2.03 update is having more than that and we dont have the device anymore to test.
I would recommend to go back to the 1.15 firmware the device was originally mapped in VDJ.
The 2.03 zip (Serato update) offers the 0115 file to downgrade.
Posted Wed 30 Oct 24 @ 6:37 pm
works perfectly with 2.03 !! thanks i consider downgrading.
Posted Wed 30 Oct 24 @ 8:31 pm
