Forum: Addons
Topic: Project Control - Page: 5
i lost all my custom buttons with the update , how can i recover ?
This is not a problem of the Skin. The Custom Buttons are saved in the VirtualDJ/settings.xml on your systemdrive.
Hi Denny
i think a found a little issue on the jog info: when i load a track on a deck that is big ( lets say 120 minutes or more ) the time remaining on the jog does not display correct . like it does not have enough space to display all the digits
Hi, Denny. I have been using the Prepare skin a lot and really love it. Is it possible to have a choice of Extra Windows be the center section of the standard layouts that has Mixer, Video, Scratch, Master?
Or, if you think of another way to give access to the Mixer section features that would be great.
Love, Live, Spin!
Riot
Hi, Have to know your skins controller & actually project control are my fauvorite skins by far, more than 3 years almost been my default skin.
Well from last updates, not sure if are early updates.... i lost the return to last folder on the browser tree, temporally i will use a custom edit button to make this funtion.
I don´t tell you like a request or claim,
I see myself in debt, and it is a very small contribution to the excellent and hard work that you develop with these skins and that has given me so many good moments... Forever thank you and best wishes to you
ed:
return to last folder button donñt was located on browser tree, was at left in additional buttons...only this aclaration...thanks...
best regards
in settings search for : previous
find option browserPreviousfoldersButton
enable it !
Thank you very much,
I'm embarrassed, I thought I knew each and every one of the settings options,
surely it will be relatively new, and I missed it, I'll have to look more carefully at the changuelogs,
thank you friend
Version 1.0.9 - 2024-04-11
add - Linked Window (at the moment it doesn't refresh automatically VDJ Build 8019)
add - Mixer Window
change - add a Supporter
change - Custombar and Prelisten works seperate on the Browserwindow
change - some Customicons
add - Mixer Window
Thanks. This skin has so many features - some which are hidden, it should hv a vid attached. Keep up the good work.
Hey Dannyo, I like the features and customization offered in your skin.
If possible, I only request that you make the 'beat counter' adjustable, able to click on segments to match timing on other decks, assisting with syncing the beats between decks, similar to how one can manipulate the phrase sync for each deck.
It will help to keep the song structure tight when mixing.
Thank you
The ability to drag and drop tracks to the waveform may help some as well.
Thank you
You mean the vertical Wave?
[quote=DennYo Beats]You mean the vertical Wave?[/quote
Yes.
Thanks
Version 1.1.0 - 2024-05-06
bugfix - small position correctures
add - rightclick on the prelisten cog hide the prelisten player on top for 5 seconds (default Browser)
add - Song dropzone on vertical Waves
add - Song Info Window 2
add - FX BAR
add - alternative Song Info (Browser Sideview on bottom)
add - alternative Searchbar (Browser Sideview on bottom)
change - Browser (Sideview on bottom)
change - visual changes
change - add Customicon Stems Prepared (Browser)
Version 1.1.1 - 2024-05-18
bugfix - Mixer Window won't show on all Variations
Just wanted to reach out and say thank you for the work and skin you have provided, most useful and a pleasure to work with.
First: Thank You !
Where is the unload button ?
I do appreciate the upgrades and updates to the skin. Thank you
Version 1.1.2 - 2024-06-15
bugfix - Audio Mixer 2 Deck small
bugfix - FX Bar 2 Deck, 3 Slots, Deck 2
change - Linked Window works now
I can't find the vertical wave layout. Only options are off, top and bottom. Using latest build.
99%
