Forum: Addons
Topic: Project Control - Page: 3
@stlvs
Please stop spamming this topic. The last post is to much. You quote another post and place your image 2 times. Why? This is a behave like a child.
I saw your wish at the first post and test some things. But i don't find the perfekt result for this.
Bring me a complete conzept for this and i can test it. what should go in the free space of the jog?
I understand the longer songpowave. But there also must be place the Timer, current BPM, Slip mode, Vinyl mode... Bring me a complete grafic.
_________________________________________________________________________________________________
@DjTasosMavrokefalos
I saw also your post.
Many changes in the code and destroi my XML code logic.
In your idea there is no place for the Browser. Also the mixer where split.
DennYo Beats wrote :
@stlvs
1st I was trying to get your attention so I can get an answer, it is not my intention to spam anything and 2nd I am not welle undesrstand how is thiw working to post a message here with a photo, that's why I upload so many photos by mistake..
Anyway forgive me for all these and forget what I am asking, it's not a big deal.. Take care..
1st every post here have my attention.
But its very timefull to add so big changes in the skin. I don't create money with this. Create Skins is a hobby from me for the community.
For example. add your wish i think 6-10 houres
Create this Skin/Interface (Project Control) to the actual point: over 3 times of all seasons Big Bang Theorie. ( 800-1000 houres)
I have a concept. look here:
Post images is simple. After upload here you have in the textbox a forumcode syntax IMAGE1 ... this syntax show the picture in your post. When you use IMAGE1 more than on time in a post the picture will duplicate.
My point for all of this is 1) longer songposwave=better detail of how the song goes or what elements it has and 2) I believe that the Jog kind of look is getting old..so I could keep the down frame with bpm, vl, sl and time details and the upper frame with all the other details (gain, key etc) ideally I would put them above the songposwave where are the title and "master" area, so the songposwave get even more larger..
I am not an expert, maybe I propose something impossible, but let me tell you that I apreciate all the work that you have done so far with all my heart, I am just sharing my ideas for something (I believe) better, that's all
This is my the current idea. you can turn off the extended Song Infos.
as a dj you should know songs that you play, such words comes from DJs they use online content that they never heare before, the jog contains the most important informations
This is IT!! That's what I'm talking about..You can have all the amount of information that you need without being them in a circle with a needle going round all the time :-)
That's perfect
Version 1.0.4 - 2023-04-17
bugfix - position bug browser and Support Page on MAC
add - Songinfos can toggle to Custum Buttons (gain,bpm,com,rate)
add - classic Beatwave and split horizontal Scratchwave
add - option to hide the Jog
change - visual changes
The Option hide Jog is for the big, middle and small Variation.
Songinfos can toggle to Custum Buttons. Customize Your Songinfos.
click on the words GAIN, BPM, COM or RATE to change to 2 custom button.
now you can click with rightclick and add your needed Informations.
for example, Button Name:
left button YEAR
right button `get_loaded_song 'year'`
On the left 4 Custom Buttons you can not use the action. The action is coded for toggle between GAIN, BPM, COM, RATE and CUSTOM.
Might as well add side by side scratch wave.
@stlvs
i didn't do it my friend.....
Version 1.0.4
split horizontal Scratchwave is side by side Scratchwave ;)
You weren't meant. The Bugfix for the Browser Position on MAC is on the way.
Perfect add the Hide-Jog option,thank you very very much!! I spot (maybe) a bug, when you select "Bigger Font" on "Text font size" some icons from "Topzone" disappears..
Your new update won't update, do I need to delete the original skin then install again?
I can confirm. I have the same on my M1 Mac.
Version 1.0.4
Just tested it. You implemented this better in Controller 2020 with more controls.
Version 1.0.5 - 2023-04-19
bugfix - The Buttons on the Topzone won't show at Text Size bigger
add - Master / Select Deck Buttons as Wave Overlay
Sorry, Ignore this all fine now
Version 1.0.4 - 2023-04-17.
This is know my default skin. Looks and works so nice.. Man this is really some work to admire.
Also, Thank you for fixing it for MAC
i get the update!!!
amazing!!!!!
thanks mate!!!!
A kindly suggestion for a future update maybe you could skip the word "bpm" from the "current bpm" frame so that the decimal digits are more distinct as well, and 2nd switching places the "bpm, VM, SL" frame with the "Timer" one might be better because you can have the standard bpm and the current one aligned one under other
59%
