Hi guys been going around in circles trying to get a custom skill built for radio broadcast and not been able to get a project started.
Posted Thu 29 Dec 22 @ 7:32 pm
If it's about just a skin and need a simple interface, try the Skin Builder (It's a skin you can find in VDJ Extensions tab of Settings). Then use the Skin Build Extractor Tool to extract to a VDJ skin.
Unless there is more than just a skin you re looking for and/or the available elements dont suit to your needs. In this case, you ll have to be more specific.
Posted Fri 30 Dec 22 @ 12:00 pm
