I'm having problems separating files for vdj to read
So i have a standard hd with folders dj music - karaoke - music video's
I just want to play dj music so i pick that folder but when searching it still takes in karaoke and vids aswell how can i tell just to search the folder that i want.
Posted Tue 29 Nov 22 @ 7:24 am
settings searchInDB
Posted Tue 29 Nov 22 @ 7:38 am
can you be a bit more precise
Posted Wed 30 Nov 22 @ 6:55 am
set it to no,
when it's set to yes a search query will return from the whole database.
there's also sidetoolbar options [dot bottom left of browser] to show only specific categories of file [music||karaoke||video]
Posted Wed 30 Nov 22 @ 7:14 am
Consider Quick Filters as an option too..
https://www.virtualdj.com/manuals/virtualdj/interface/database/search/index.html#quickfilter
If you dont toggle that much between the Types, then maybe the last Quick Filter button is what u only need.
Posted Wed 30 Nov 22 @ 7:52 am
think i'm sorted found in browser options show only dj music karaoke or video so just picked dj .
thanks for your help
Posted Wed 30 Nov 22 @ 9:49 pm
