HELLO, I THINK THERE IS SOMETHING WRONG WITH THE MAPPING OF S7 PADS... MOVING BETWEEN HOT CUES AND SAMPLER DOESNT CHANGE COLOUR AND CAN BE CONFUSING... IT CAN BE ON SAMPLER MODE BUT ALSO SHOWING HOT CUE MODE... PLEASE PROVIDE A FIX... IT WORKS FINE ON SERATO I CHECKED... THANKS
Posted Thu 07 Apr 22 @ 1:50 pm
Remember that the way something works on Serato is rarely what you want to copy, because it's usually pretty limited
So the question is how it should work in VDJ with all the extra features VDJ has to offer
Also remember that the pads mappings are changeable in VDJ, and thereby also on VDJ hardware - you can change it on the fly in the pad page dropdown
And you can use your own pad implementations by using pad pages
And that you can have split mode on pads in VDJ, and thereby also on VDJ hardware
Posted Thu 07 Apr 22 @ 2:37 pm
See here on how to assign pads:
https://www.virtualdj.com/manuals/hardware/pioneer/djms7/layout/pads.html
And it sounds like perhaps you have turned on split pads?
See here:
https://www.virtualdj.com/manuals/virtualdj/interface/decks/decksadvanced/pads.html#split
See here:
Posted Thu 07 Apr 22 @ 2:46 pm
HELLO THANKS FOR THE REPLY... I THINK ITS HARD TO EXPLAIN... THE S7 MAPPINGS ARE CORRECT HOWEVER I HAVE PUT A VIDEO LINK FOR YOU TO SEE... LIGHTS ARE TURNING ON WHEN THERE NOT SUPPOSED TO... https://youtube.com/shorts/P6SpCK_0Z0Y?feature=share ... IF I PRESS SAMPLER ON DECK B DECK A CHANGES TO SAMPLER COLOURS WITHOUT TOUCHING IT... AND DECK LIGHT BOTH HOT CUE AND SAMPLER AT THE SAME TIME... CHECK THE LINK PLEASE..
Posted Thu 07 Apr 22 @ 5:13 pm
Indeed it seems there is a typo in our files. Will be fixed soon
Posted Thu 07 Apr 22 @ 9:48 pm
THANK YOU FOR NOTICING... BUT WHAT I LOVE ABOUT VIRTUAL DJ... FOR THE TIME BEING I JUST CHANGED THE SAMPLER TO ANOTHER BUTTON... NICE N EASY... ITS WORKING FINE WITH THE SAVED LOOP BUTTON.
Posted Fri 08 Apr 22 @ 1:18 am
Fix is available in Early Access Build
Enable EarlyAccessUpdates from VirtualDJ Options and restart VDJ (you may have to restart VDJ once again to get some silent controllers update)
Posted Sat 09 Apr 22 @ 9:43 pm
