Hi guys,
My Reloop controller has been working on my new windows laptop for the past three weeks. On Saturday, Virtual DJ wouldn’t recognise my controller as a midi device, fine as a soundcard, but I couldn’t use any of the controller functions, volume, crossfade, stems, pitch, pads.
I’ve reinstalled VDJ, driver and done a windows update and no joy.. any ideas?
Posted Wed 02 Mar 22 @ 1:16 pm
Works fine here.
disableBuiltinDefinitons setting is set to No, right ?
Left-side switch is set to PC ?
It definitely needs the driver for the Midi to work, so something didnt go well with the driver installation.
I suppose MIDIOX ( http://www.midiox.com/ ) doesnt recognize the device either ?
BTW, try this driver version.. https://cloud.reloop.com/index.php/s/ks87jVsSTEjUSlT has a small fix (shared from Reloop)
Posted Wed 02 Mar 22 @ 1:55 pm
could it be the mapping is set to, ignore ?
not likely but a possible cause.
Posted Wed 02 Mar 22 @ 2:10 pm
Bonjours à tous
Récemment j'ai fait l'acquisition du contrôleur Reloop Neon
Je suis avec la version Virtuel Dj 7 Pro
avec la console Denon MC3000
Le logiciel ne semble pas reconnaitre le Reloop Neon
et quand je relance Virtuel DJ 7 il me donne un message d'erreur (manque un ,dll)
comment régler mon problème
Posted Sat 01 Oct 22 @ 3:56 pm
VDJ 7 support ended in 2014, and obviously controllers released since that time will not be mapped. You don't appear to have a license anyway...
Posted Sat 01 Oct 22 @ 6:14 pm
groovindj wrote :
oops
Posted Sat 01 Oct 22 @ 6:16 pm
