Hi, how to enable multi effect  (to control three effects) on Prime 4? There is link in user manual to press Shift and TAP, but there is no TAP button on Prime 4. When I do change in Virtual DJ GUI, nothing happens on my Prime 4. Any ideas, how to fix that.
Thanks, Tomas.
    Thanks, Tomas.
Posted Mon 04 Oct 21 @ 10:22 am
          The selection between those 2 modes is done from the VirtualDJ GUI.
https://www.virtualdj.com/manuals/virtualdj/interface/decks/decksadvanced/effects.html
We removed the incorrect text from the manual
If you wish to have a button on your Prime to toggle between the 2 modes, you can assign a button as ..
effect_3slots_layout
Posted Mon 04 Oct 21 @ 12:37 pm
          Great. Thank you.
    Posted Mon 04 Oct 21 @ 4:57 pm
