I'd like to share my experiences of connecting Sunlite Suite 3 to VirtualDJ.
1)
To get the communication running, set the setting "os2lDirectIp" to "127.0.0.1:8010". With this setting "Bonjour" is not needed.
2)
Create buttons on the "_MASTER" page. Set the button names to lower case in VirtualDJ. Sunlite Suite 3 does use a case insensitive compare, so even if you use a name like "Scene1" you should use "scene1" in VirtualDJ. Otherwise VirtualDJ will not be able to update the status of the pad buttons.
Example: os2l_button "scene1"
If use create buttons on another page, also make sure the page name is lower case.
Example: os2l_button "page1" "scene1"
I've used WireShark to follow the OS2L communication. I found that Sunlite Suite is sending events with lower case button names.
I still have to find out how to use "os2l_cmd".
1)
2)
Posted Tue 06 Apr 21 @ 12:06 pm
Can see here on how to use CMD
https://www.virtualdj.com/wiki/os2l.html
Posted Tue 06 Apr 21 @ 3:08 pm
Good to know OS2L is implemented in Sunlite Suite 3. They started with Suite 2, and Suite 3 was expected to follow.
I believe the case sensitive issue has been fixed in OS2L, but probably Sunlite developers havent updated their code
Posted Tue 06 Apr 21 @ 3:41 pm
hello everybody
i try since a long time to use OS2L action
it run when the DMX command is on MASTER page do not run if the page is different like this syntax
Os2l_Button "WW1 WBGR" "WW1 1 R"
it will be nice of you to return your experience to me, i do not go here everyday, so your answer by email : Moderator No email from home licence users
Posted Sat 20 Nov 21 @ 7:25 pm
i try to understand this code :
<Song FilePath="D:\YOUTUBE\Playlist 7 - FUNK 2021\matt-early-ray-hurley-feat-abi-flynn-get-to-me-once-original-mix.mp3" FileSize="15951768">
<Tags Author="Matt Early & Ray Hurle" Title="Get To Me Once (Original Mix)" Remix="Abi Flynn" Year="20190805" Flag="1" />
<Infos SongLength="474.012167" LastModified="1637435683" FirstSeen="1632758201" FirstPlay="1632758871" LastPlay="1637433666" PlayCount="21" Bitrate="269" Cover="8225" />
<Comment>1</Comment>
<Scan Version="801" Bpm="0.48780" AltBpm="0.365850" Volume="0.988373" Key="E" Flag="49156" />
<Poi Name="DMX" Pos="0" Num="-1" Color="4294901760" Type="action" Action="os2l_button "BLACKOUT"" />
<Poi Pos="0" Num="1" Type="cue" />
<Poi Name="DMX" Pos="1.5" Num="-1" Color="4278190335" Type="action" Action="os2l_button "WW1-WBGR" "WW1-B"" />
<Poi Name="DMX" Pos="3.5" Num="-1" Color="4294901760" Type="action" Action="os2l_button "WW1-WBGR" "WW1-R"" />
<Poi Name="DMX" Pos="5.5" Num="-1" Color="4278190335" Type="action" Action="os2l_button "WW1-WBGR" "WW1-B"" />
<Poi Name="DMX" Pos="7.5" Num="-1" Color="4294901760" Type="action" Action="os2l_button "WW1-WBGR" "WW1-R"" />
<Poi Name="DMX" Pos="10" Num="-1" Color="4278190335" Type="action" Action="os2l_button "WW1-WBGR" "WW1-B"" />
<Poi Name="DMX" Pos="11.290568" Num="-1" Color="4294901760" Type="action" Action="os2l_button "WW1-WBGR" "WW1-R"" />
<Poi Name="DMX" Pos="13.241026" Num="-1" Color="4278190335" Type="action" Action="os2l_button "WW1-WBGR" "WW1-B"" />
<Poi Name="DMX" Pos="15.195382" Num="-1" Color="4294901760" Type="action" Action="os2l_button "WW1-WBGR" "WW1-R"" />
<Poi Name="DMX" Pos="17.144332" Num="-1" Color="4278190335" Type="action" Action="os2l_button "WW1-WBGR" "WW1-B"" />
<Poi Name="DMX" Pos="19.0" Num="-1" Color="4294901760" Type="action" Action="os2l_button "WW1-WBGR" "WW1-R"" />
<Poi Name="DMX" Pos="21.0" Num="-1" Color="4278190335" Type="action" Action="os2l_button "WW1-WBGR" "WW1-B"" />
<Poi Name="DMX" Pos="22" Num="-1" Color="4294901760" Type="action" Action="os2l_button "WW1-WBGR" "WW1-R"" />
<Poi Name="DMX" Pos="24" Num="-1" Color="4278190335" Type="action" Action="os2l_button "WW1-WBGR" "WW1-B"" />
<Poi Name="DMX" Pos="27" Num="-1" Color="4294901760" Type="action" Action="os2l_button "WW1-WBGR" "WW1-R"" />
<Poi Name="DMX" Pos="29" Num="-1" Color="4278190335" Type="action" Action="os2l_button "WW1-WBGR" "WW1-B"" />
<Poi Name="DMX" Pos="31" Num="-1" Color="4294901760" Type="action" Action="os2l_button "Rouge"" />
<Poi Name="DMX" Pos="33" Num="-1" Color="4278190335" Type="action" Action="os2l_button "Bleu"" />
<Poi Name="DMX" Pos="35" Num="-1" Color="4294901760" Type="action" Action="os2l_button "Rouge"" />
<Poi Name="DMX" Pos="37" Num="-1" Color="4278190335" Type="action" Action="os2l_button "Bleu"" />
<Poi Name="DMX" Pos="39" Num="-1" Color="4294901760" Type="action" Action="os2l_button "Rouge"" />
<Poi Name="DMX" Pos="41" Num="-1" Color="4278190335" Type="action" Action="os2l_button "Bleu"" />
<Poi Name="DMX" Pos="43" Num="-1" Color="4294901760" Type="action" Action="os2l_button "Rouge"" />
<Poi Name="DMX" Pos="44.464709" Num="-1" Color="4278190335" Type="action" Action="os2l_button "Bleu"" />
<Poi Name="DMX" Pos="46.411474" Num="-1" Color="4294901760" Type="action" Action="os2l_button "Rouge"" />
<Poi Name="DMX" Pos="48.368342" Num="-1" Color="4278190335" Type="action" Action="os2l_button "Bleu"" />
<Poi Name="DMX" Pos="50.315107" Num="-1" Color="4294901760" Type="action" Action="os2l_button "Rouge"" />
<Poi Name="DMX" Pos="52.760351" Num="-1" Color="4278190335" Type="action" Action="os2l_button "Bleu"" />
<Poi Name="DMX" Pos="54.215372" Num="-1" Color="4294901760" Type="action" Action="os2l_button "Rouge"" />
<Poi Name="DMX" Pos="56.168872" Num="-1" Color="4278190335" Type="action" Action="os2l_button "Bleu"" />
<Poi Name="DMX" Pos="58.168667" Num="-1" Color="4294901760" Type="action" Action="os2l_button "Rouge"" />
<Poi Name="DMX" Pos="60" Num="-1" Color="4278190335" Type="action" Action="os2l_button "Bleu"" />
<Poi Name="DMX" Pos="62" Num="-1" Color="4294902015" Type="action" Action="os2l_button "BLACKOUT"" />
<Poi Name="DMX" Pos="63.25" Num="-1" Color="4294934272" Type="action" Action="os2l_button "MACRO 8"" />
<Poi Name="DMX" Pos="70.30" Num="-1" Color="4294934272" Type="action" Action="os2l_button "MACRO 7"" />
<Poi Name="DMX" Pos="78.15" Num="-1" Color="4294901760" Type="action" Action="os2l_button "WW1 WBGR" "WW1 1 R"" />
<Poi Pos="156.180627" Num="-1" Color="4294967040" Type="remix" />
</Song>
</VirtualDJ_Database>
it seams to be good if we do not want to place the DMX poi on VDJ, but on a wordpad
if some one have any experience on this, i'd like to get it
this code is on database.xml
</Song>
Posted Sat 20 Nov 21 @ 7:28 pm
bpm is measured in seconds per beat [this can lead to tiny rounding errors and I mean tiny like fractions of a sample, I don't know if this could be improved with allowing a divide operation, instead of a single beat use multiple beats and include a divide, the problem is deeper than I what I understand of the bpm engine]
pos is a measure in seconds
Num is cue number, -1 indicates marker [invisible has no number indication]
color is android.graphics.Color encoding
actions use xml escape chars
If you're editing at the xml level be sure to have backups, one typo could corrupt your database. I can't see working this way being all that successful to be honest.
I made an app to add action poi quickly from inside vdj, but it uses a auto hot key type send keystrokes action, so, it is not safe to use in a performance setting and will never be officially released, and it must be used with caution.
I won't embed the video but here's a link of it being used.
https://youtu.be/x_Oz0QvY7oc?t=11
Good luck.
Good luck.
Posted Sat 20 Nov 21 @ 11:26 pm
I've tried to setup my connection to Virtual DJ (VDJ) and Sunlite Suit3 with OS2L, but the BPM is not passing from VDJ to Sunlite Suit3. I'm not sure what I'm doing wrong. Is there any step-by-step instructions to correctly set it up or can you provide any advice?
Posted Fri 28 Jul 23 @ 2:38 am
