Hi,
The Roland 808 offers one channel fx Knob for each of the 4 channels. On my controller works only the channel fx knob of channel 1 and affect all channels at the same time. What is wrong? What can i do? Thanks for your valued support.
Posted Sun 27 Dec 20 @ 10:28 am
Are you referred to the FX buttons [53] from the manual ? https://www.virtualdj.com/manuals/hardware/roland/dj808/layout/effects.html
If so, please read their functionality. There is no Effect "Assign" in VirtualDJ, so these are used to just copy the effects from one Deck to the other.
Posted Sun 27 Dec 20 @ 4:39 pm
Thanks for your answer but i talked about the knob nr. 6 in the manual and CHANNEL FX Nr. 7. Only the Effect "Noise" is working on channel 2.
Posted Sun 27 Dec 20 @ 7:25 pm
Hi again
I will try to explain it better.
The Roland 808 offers one channel fx Knob (Nr. 6 in the VDJ Manual) for each of the 4 Decks. On my controller works only the channel fx knob of Deck 1 when a Hardware channel FX (Nr. 7 in the Manual) is activated. Somehow the applied Effect influence all 4 Decks at the same time when i turn the knob (Nr. 6). So the decks cannot be regulated separately. But according to the manual that should be possible. Apperently the Knob (Nr. 6) of Deck 2-4 is dead.
What is wrong? What can i do? The Fimware is up to date with the latest version 1.10. Thanks for your valued support.
Posted Tue 29 Dec 20 @ 7:55 pm
The Channel FX knobs apply a Hardware Effect. Double-check your AUDIO Setup as per the manual https://www.virtualdj.com/manuals/hardware/roland/dj808/setup.html
Apparently, speakers need to be connected to the Master Out of the 808
Posted Tue 29 Dec 20 @ 9:06 pm
Thank you, thank you, thank you. Problem solved. The outputs where wrong. Now i will buy a licence and put the included serato software to the side. I m really happy right now. Thank you.
Posted Wed 30 Dec 20 @ 7:34 am
