Can you upload the settings.xml file that causes the crash and post the link here ?
Or you get the crash without changing anything from the default settings ?
May not be much useful as the crash is related to the DDJ Asio, but curious to see what you have changed there.
Posted Tue 09 Jun 20 @ 11:40 am
i just tried the copy settings file, with and without DDJ turned on, and youre right, its the DDJ that causes the crash.
but i updated the driver and firmware and theres not much more to do from the controller side.
Should i update the driver once again?
Posted Wed 10 Jun 20 @ 5:39 am
bump.
please help, it is still not working.
should i delete and reinstall vdj completely?
Posted Thu 09 Jul 20 @ 8:46 am
Try renaming your Documents> VirtualDJ> settings.xml file while VDJ is closed then try again. Your settings file may be corrupted.
Posted Thu 09 Jul 20 @ 8:48 am
You previously said you were using Windows - but which version?
The DDJ-RR drivers require Windows 8.1 or 10.
Posted Thu 09 Jul 20 @ 9:21 am
thank you, i will try renaming the settings file again.
and yes, im using windows 10.
Posted Fri 10 Jul 20 @ 12:58 pm
ok so renaming the settings file does make vdj work again, but only for one time. at the second startup it crashes again.
please can anyone tell me a definitive solution to this?
Posted Mon 20 Jul 20 @ 8:41 am
.....and you made no changes to the settings, in config or on the skin you're using?
Posted Mon 20 Jul 20 @ 8:45 am
no i did not change anything.
Posted Tue 21 Jul 20 @ 4:37 am
Adion wrote :
There is one crash logged which appears to be the DDJ-RR asio driver crashing.
What settings do you have for your ASIO driver (latency/buffer size)? If you make it too small, it could be causing issues.
You could also try uninstalling the ASIO driver and just using WASAPI.
Posted Tue 21 Jul 20 @ 10:04 am
