Hi I’m Surendra and I have a problem with my numark mixtrack.i was trying to use it for the virtual Dj 2029 but it always say license expired.i tried typing in the key that came with it and it says it’s not a valid code for a license.i got this controller from my uncle and it does not work with it.the key number works with the original install cd and when I try to update it,it still say the same things.
Surendra Bridgnanan
Surendra Bridgnanan
Posted Sun 24 May 20 @ 12:10 am
Apparently you have a ver 7 VirtualDJ LE keycode - which came with the Mixtrack, but it's not valid for version 8+ (2020).
Version 8 allowed you to use your controller during the Trial period, but you will need a license to continue using that.
Options.
1. Enter your LE7 keycode at http://www.virtualdj.com/le/ , download, install and use version 7 LE for free.
2. Buy a version 8 license (Plus, Pro or Pro subscription) from https://www.virtualdj.com/buy/index.html
Options.
Posted Sun 24 May 20 @ 2:05 am
