Topic: Tech specs for broadcasting.
I’m having issues with broadcasts dropping and freezing. Wondering if I can have someone tell me what I need to do. I have 150 mps down and 10 mps up. Using WiFi maybe 25 feet from modem. Separated by a wall. Running windows 7 on a HP laptop that’s about 15 years old. Signal is strong according to bars. Have zero issues with the VDJ, runs incredibly smooth. My friends are telling me that the BC keeps stopping. Would hard wired work better? Extender? Is it a WiFi antenna issue? Thoughts? Much obliged!!!
Posted Thu 28 Feb 19 @ 5:14 am
You can first try to record instead of broadcasting, just to see if the "result" is good to go or have interruptions due to low computer specs and performance.
Then i would try to use Ethernet connection - temporary set your computer next to your router - and see if that works well.
Posted Thu 28 Feb 19 @ 2:19 pm
