Topic: Virtual Dj 8 problem
My Headphones gets active if i touch the wheel and i cant scratch with way can i turn this off someway?
Posted Fri 08 Jun 18 @ 1:41 pm
some more infos would be helpful:
OS, VDJ build-No., controller etc....
Posted Fri 08 Jun 18 @ 2:24 pm
From VirtualDJ Settings-->OPTIONS tab, search for the setting autoHeadphones and set it either to No or On Load
Posted Fri 08 Jun 18 @ 4:44 pm
