This is a new SB3, and it works fine with Serato, but it's not working at all with VDJ. I've tried with 2 computers (one Win7, one Win10), USB 2.0 and USB 3.0 ports, version 8.2.b3994 as well as 8.2.b4189. Same thing happens consistently every time.
First, I plug in the SB3 USB. Then I load VDJ, and it freezes instantly on load and crashes when I interact with it. After it crashes, I can load VDJ fine, but the SB3 shows up as "failed to connect" in the settings:
https://i.imgur.com/Tc8HjQZ.png
My computer seems to recognize and install the SB3 drivers:
https://i.imgur.com/2j0KqdB.png
And my audio settings don't have it as the default device:
https://i.imgur.com/ih67NKm.png
Anyone have an idea of how to fix this issue?
Posted Mon 26 Mar 18 @ 4:51 pm
Problem was that it needed version 4204, not version 4189 like the other topic on this forum said!
Posted Mon 26 Mar 18 @ 8:13 pm
How did you fix the problem? I have the same one.
Posted Fri 30 Mar 18 @ 11:04 pm
same problem in failed to connect.. no idea my build is b4514 (newbie)
Posted Thu 13 Dec 18 @ 9:02 am
Without the SB3 plugged, update VDJ to the latest Build, then plug it to USB
Posted Thu 13 Dec 18 @ 11:43 am
