Topic: NVii Midi Problem
I just purchased a Numark NVii.
I am using the latest VDJ build and got the prompt that said that the NVii is plug and play.
The controller list does not show an option for
Numark NVii
It only shows
Numark NVii Display Right
Numark NVii Display Left
So I can manually load a song via laptop, it will show up on the display, but none of the hardware controls work
Can I get some help getting it to recognize Numark NVii?
Posted Fri 26 Jan 18 @ 5:04 am
Have you tried a different USB cable/port ?
Any additional USB device/controller connected at the same time ? If so, try without it.
Which Windows Driver have you installed from here ? https://www.numark.com/product/nvii
Not sure when the 1.05 was released, but in the Release notes file i see "Updated driver signature for certain Windows operating systems. "
When the NVII is plugged, do you see the device in Windows Device Manager (under Sound, Video & game controllers) or perhaps a yellow triangle ?
Posted Fri 26 Jan 18 @ 5:23 am
Tried multiple ports and 2 cables
No other controllers
I downloaded the latest "1.05, I'll uninstall restart and try 1.02
The device does show up, no triangles
Posted Fri 26 Jan 18 @ 5:35 am
Please do the following...
Open VirtualDJ and goto Settings-->OPTIONS tab
Find the setting "CreateMidiLog" and set it to Yes
Close VirtualDJ
Goto /Documents/VirtualDJ folder and delete the file Log Report.txt
With the NVII connected to the USB, open VirtualDJ
Close again (dont have to do anything else)
Post here the content of the Log Report.txt that has been re-generated from the above location.
Posted Fri 26 Jan 18 @ 5:45 am
--- 2018/01/25 - 23:56 (3994)
Audio device found: name="Realtek High Definition Audio" vid="0x10EC" pid="0x0269" hardwareID:"{0.0.0.00000000}.{246bb583-1c83-4e29-9789-5236f51a3774}"
Audio device found: name="Speakers (4- NV mkII Audio)" vid="0x15E4" pid="0x103B" hardwareID:"{0.0.0.00000000}.{55e92ad4-9ecd-4b7d-9748-3059b1026660}"
Audio device found: name="Line 3/4 (4- NV mkII Audio)" vid="0x15E4" pid="0x103B" hardwareID:"{0.0.0.00000000}.{be584298-0090-4e4b-bea3-976116a9b09c}"
Audio device found: name="Line 1/2 (4- NV mkII Audio)" vid="0x15E4" pid="0x103B" hardwareID:"{0.0.0.00000000}.{e385b4b5-fcef-429d-acd0-add55ea41af6}"
Audio device found: input name="Realtek High Definition Audio" vid="0x10EC" pid="0x0269" hardwareID:"{0.0.1.00000000}.{f848736f-509e-4e2f-813f-bd504619980f}"
Audio device found: asio="4Trak USB Audio Device" hardwareID:"F479E46B-79CF-4446-B94189E5B097126F"
Audio device found: asio="ASIO4ALL v2" hardwareID:"232685C6-6548-49D8-846D4141A3EF7560"
Audio device found: asio="FL Studio ASIO" hardwareID:"188135E1-7171-3434-854F01A3C71F3DF9"
Audio device found: asio="Focusrite USB 2.0 Audio Driver" hardwareID:"FB9128CA-3663-410E-B3F55DB78DA44432"
Audio device found: asio="Numark NV mkII ASIO" hardwareID:"3C8C7FCA-82E5-42CD-AA27CB085E4312A8"
Audio device found: name:FL Studio (REWIRE) hardwareID:"FL Studio"
Midi out device detected, name:Microsoft GS Wavetable Synth mid:1 pid:27
MIDI Device Identifying: \\?\usb#vid_15e4&pid_203b&mi_00#8&22bcf268&0&0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\nvmkiigraphics (in:0 out:1)
MIDI Device Identified by PID/VID: \\?\usb#vid_15e4&pid_203b&mi_00#8&22bcf268&0&0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\nvmkiigraphics : Numark NVII Display Right
MIDI Device Identifying: \\?\usb#vid_15e4&pid_103b&mi_00#8&f8cd62a&0&0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\nvmkiiaudio (in:1 out:2)
MIDI Device Identified by PID/VID: \\?\usb#vid_15e4&pid_103b&mi_00#8&f8cd62a&0&0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\nvmkiiaudio : Numark NVII Display Left
MIDI Device Identifying: Microsoft GS Wavetable Synth (in:-1 out:0)
[23:56] Midi Out Closed (Microsoft GS Wavetable Synth)
MIDI Device Not Identified: Microsoft GS Wavetable Synth
HID Device found: VID:0x3938 PID:0x1032 path:\\?\hid#vid_3938&pid_1032&mi_01&col02#7&39ad492&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}
HID Device found: VID:0x3938 PID:0x1032 path:\\?\hid#vid_3938&pid_1032&mi_01&col03#7&39ad492&0&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}
HID Device found: VID:0x3938 PID:0x1032 path:\\?\hid#vid_3938&pid_1032&mi_01&col04#7&39ad492&0&0003#{4d1e55b2-f16f-11cf-88cb-001111000030}
HID Device found: VID:0x3938 PID:0x1032 path:\\?\hid#vid_3938&pid_1032&mi_01&col05#7&39ad492&0&0004#{4d1e55b2-f16f-11cf-88cb-001111000030}
[23:56] Midi In Closed (\\?\usb#vid_15e4&pid_203b&mi_00#8&22bcf268&0&0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\nvmkiigraphics)
[23:56] Midi Out Closed (\\?\usb#vid_15e4&pid_203b&mi_00#8&22bcf268&0&0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\nvmkiigraphics)
[23:56] Midi In Closed (\\?\usb#vid_15e4&pid_103b&mi_00#8&f8cd62a&0&0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\nvmkiiaudio)
[23:56] Midi Out Closed (\\?\usb#vid_15e4&pid_103b&mi_00#8&f8cd62a&0&0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\nvmkiiaudio)
Posted Fri 26 Jan 18 @ 5:56 am
Doesnt seem to detect the main unit. Could be a faulty unit, or something went wrong with Windows generic MIDI detection.
Does it work with Serato ?
Try this tool http://www.virtualdj.com/download/miditrace.exe (with VDJ closed)
Do you see 3 Numark NVII devices at the side lists or just 2 ?
Posted Fri 26 Jan 18 @ 6:24 am
Would not work with Serato either.
Midi Trace shows
4- NV mkII Graphics
4- NV mkII Audio
Posted Fri 26 Jan 18 @ 6:29 am
Restart computer (if you havent done already)
Try with another computer (if available)
If none of the 2 above helps, contact seller, most likely a faulty unit
Posted Fri 26 Jan 18 @ 6:37 am
Looks like the problem exists on 2nd machine also.
Guess this is a hardware issue and I'll have to return it. :(
Thanks for all your help!
Posted Fri 26 Jan 18 @ 6:51 am
