Forum: VirtualDJ Skins
Topic: Blocks Skin - Page: 5
I love the fact that new layouts can be added without the need to add graphics to the bitmap file. :-)
May I suggest that the rhythmwave is made the same height as the deck, and the transport buttons positioned vertically between the windows...
Version 5 is now available with 2 new variations, 6 Decks (2 +4 mini) and a Single Deck for preparations, Automix, Single Player etc
Single Deck
Much in love with Blocks skin. There are many variations possible for all to work with.
The 4 decks with mixers is my favourite. I use it as a Independant radio dj to have the same playout system on several stations with different automation and Music libraries.
What i hope that it will added and be possible in the 4 decks with 4 mixer panel is that i can toggle off the horizontal waves as it take up a lot of screensize for my needs.
I have this skin on my desktop and laptop. There is no cross fader on the desktop one.
Both are set up the same.
No they're not. One has the mixer enabled. The other doesn't.
Did a reinstall and it's okay, so I can't verify if mixer was not enabled.
Thanks
You can - check the icons in the images you posted.
Got it. Do not recall changing it.
Must have though.
Thanks
It look the waveform for track is very hard to see color after update for 2021 . can this be adjust ?
before new update of VDJ it very bright and easy see . now color very dark.
thank you any help .
