Topic: Definiting Sysex RGB LED pads
NuzzletPRO InfinityMember since 2015
This Sysex message is used to set a full RGB color of one of 64 pads on my Ableton Push
Quote :
240 71 127 21 4 0 8 pad 0 rHi rLo gHi gLo bHi bLo 247
I already have a definition and a created a custom color table that matches the 0-127 midi velocities. But this is extremely limiting and I want to choose more colors. How can I set this up in my definition file so I can pick almost any color? Thanks.
Posted Mon 20 Feb 17 @ 1:14 pm
We dont offer at the moment something to combine r,g,b inside a sysex, but you can try the following, just to see if its working that way...
<text sysex="F0477F15040008XX00000000000000F7">
<digit name="LED_PAD_XX_RED" offset="9" nbbits="14" offsetbit="0" />
<digit name="LED_PAD_XX_GREEN" offset="11" nbbits="14" offsetbit="0" />
<digit name="LED_PAD_XX_BLUE" offset="13" nbbits="14" offsetbit="0" />
</text>
in the sysex you keep the bytes that dont change, and replace the ones that do with 00. Also replace XX with the Pad number.
(240 71 127 21 4 0 8 is F0 47 7F 15 04 00 08 in hexadecimal)
and then in mapping try to send constant values to see if its working.. so something like..
LED_PAD_XX_RED : constant 255
LED_PAD_XX_GREEN : constant 0
LED_PAD_XX_BLUE : constant 0
(should offer a red LED)
or
LED_PAD_XX_RED : constant 0
LED_PAD_XX_BLUE : constant 127
should offer a dark blue
In theory this should be also offered , but not sure if its working ...
<ledsysex value="F0477F15040008XX00000000000000F7">
<color name="LED_PAD_XX" bit="64" nbbits="42" bitspercolor="14" />
</ledsysex>
and then in mapping LED_PAD_XX : pad_color XX
Posted Mon 20 Feb 17 @ 4:30 pm
Very interested, I'll see what happens with the launchpad2
Posted Mon 20 Feb 17 @ 6:17 pm
</text>
or
</ledsysex>
This did work. I was able to set R G B separately 0-127 within the mapper. I will now try your second suggestion.
Posted Mon 20 Feb 17 @ 8:26 pm
I do not think the Launchpad has the ability for full sysex rgb control like the Push. The launchpad does however have a very similar velocity color palette as the push as shown hhre:
http://forum.launchpad-pro.com/viewtopic.php?id=4055
Posted Mon 20 Feb 17 @ 8:43 pm
