Discussions about VirtualDJ, and about DJing in general
If you need extended support, contact our Support Team.
(*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
Topic: Issue with startupspeed and brakespeed
artfratHome userMember since 2017
Hi everyone, I'm a VDJ newbie and i'm having trouble with these functions. I tried to assign them to two knobs of my controller, with which I can set the percentage of "startupspeed" and "brakespeed" (to give a vinyl effect, y'know), but this happens to work only on the right deck. Any ideas? Thanks in anticipation for your patience if you'll answer :)
Posted Fri 17 Feb 17 @ 2:39 pm
What is the action you are using?
Posted Fri 17 Feb 17 @ 3:49 pm
I just set these two, "startupspeed" and "brakespeed" to two sliders in the control settings. they only work for the right deck. what action should i insert?
Posted Sat 18 Feb 17 @ 1:28 pm
If you dont specify the deck (e.g. deck 1 startupspeed) or if those sliders dont exist on both sides of your controller, then they will work to the selected/default deck . You can toggle between decks using the TAB keyboard button.
Posted Sat 18 Feb 17 @ 1:37 pm
