A new wiki page for the <split> panels is available at http://virtualdj.com/wiki/Split%20panel.html (a skin example is also available to download)
Please use this topic to ask questions or comment anything regarding split panels.
A dedicated wiki page about how split panels can be used to create your own custom browser http://www.virtualdj.com/wiki/Custom%20Browser.html (not 100% finished atm)
Posted Tue 07 Feb 17 @ 9:41 pm
Thank you!
Posted Sun 12 Feb 17 @ 4:18 pm
thanks ;o)
Posted Mon 13 Feb 17 @ 10:33 pm
Custom Browser Wiki page available http://www.virtualdj.com/wiki/Custom%20Browser.html
Just the bottom "more in Depth" part is missing for now, but will be offered soon.
PS. You may need to update your VirtualDJ to the latest Early Access build, as some features were added very recently.
Posted Wed 01 Mar 17 @ 5:36 pm
Thanks, but some of the elements are still not working correctly.
i.e. when using sideview in its own dedicated skin area (not as part of the default browser) the 'sideview triggerpad' button which switches between pad view and grid(?) view doesn't function. The view doesn't change.
You can see this on V8 but by FRUiT. Use the automix/karaoke layout, select sampler in the sideview panel, then try to switch sampler views.
This bug has been there since VDJ 8 was released.
Posted Wed 01 Mar 17 @ 6:10 pm
