Can this create "VIDEO" skins, like for broadcasting??
Posted Tue 29 Apr 25 @ 1:21 pm
In theory, any skin created with Skin Builder and Extractor can be used as a Video skin, by just moving the generated zip skin file from /Skins to /VideoSkins folder.
But there are some things that will need manual modification, like removing the logo, min, max,close buttons and probably add some elements not available in Skin Builder
Posted Tue 29 Apr 25 @ 2:23 pm
Ok, Thanks for the info. Hopefully we can get this setup in a future update??
Posted Wed 30 Apr 25 @ 4:36 pm
Is there any way to add a panel without cloning or mirroring? I want to manually add panels to the same side of the screen, but there's no way.
Posted Wed 17 Sep 25 @ 5:04 pm
