I set a cue point where I want the song to start. I shut down VDJ and restart and the cue point is there but the song does not cue to that point.
I have tried each and every selection under "autocue" and nothing worked for me. My music collection is in itunes, if that makes a difference.
I am POSITIVE that I am doing something wrong and it's not VDJ acting up but can anyone tell me the step or two that I am missing?
Many thanks!
Scott
Many thanks!
Scott
Posted Mon 17 Oct 16 @ 10:01 pm
Is it Cue 1 the one that you set ? Thats what autoCue to Cue uses. If you need to use a different Cue, you need to set that as Load Point from the POI Editor
BTW, cue points set using the CUE button are not stored. You need to use HotCues.
Posted Mon 17 Oct 16 @ 10:23 pm
Makes sense.
Any way to get the cue button to actually set the first cue and make it the load point? That would be a good option.
Posted Tue 18 Oct 16 @ 3:50 pm
Posted Tue 18 Oct 16 @ 6:09 pm
