Experiencing two issues:
1. The crashing of my system when using a right mouse click to save a playlist has returned for the 3rd time. It was fixed as recently as b3420 but has returned with b3440.
2. When I try to revert back to a previous build (b3440 to b3420), the VDJ installer says that it is doing so but when I open VDJ to check, the current build of 3440 remains.
Thank you.
Gear:
MacBook Pro with Retina Display OS 10
Thank you.
Gear:
Posted Sun 16 Oct 16 @ 9:15 pm
Sorry, but where exactly do you have to right-click in order to save a Playlist ?
Posted Mon 17 Oct 16 @ 11:49 pm
Hi Djdad- I'm referring to the cut and paste operation of where you copy something to the clipboard ((a playlist name) and then right mouse click to paste the clipboard info into the save as dialogue box. I see now that I was unclear.
The latest build seems to have corrected the issue.
Thank you.
Posted Tue 18 Oct 16 @ 6:33 pm
