Hey guys,
I've made a script for my controller for VDJ7 last year and it works fine!
Now I want to switch to VDJ 8.2, but the controller doesn't work.
I can choose it in the controllersection of the config, but when I do it doesn't work! VDJ8.2 doesn't do anything when I press a button on my controller.
Is there a difference in het two XML files (device and mapper) between VDJ7 and VDJ 8.2?
I mean, do I have to use other commands or something like that?
Thanks in advance for your help!
Posted Sun 16 Oct 16 @ 4:43 pm
What controller? Have you tried adding the word "force" to the start of the def file file name?
Posted Sun 16 Oct 16 @ 4:51 pm
Hey Locodog,
the controller is my D&R Airence mixer, in VDJ I use the faderstart for starting the songs.
Where exactly do I have to add the word force?
Posted Sun 16 Oct 16 @ 6:01 pm
Example
"definitionFile.xml"
becomes
"force - definitionFile.xml"
in the devices folder
becomes
Posted Sun 16 Oct 16 @ 6:06 pm
No, doesn't make it work.
Here's the def file:
<?xml version="1.0" encoding="UTF-8"?>
-<device reportsize="32" pid="0x2402" vid="0x03eb" decks="4" type="HID" description="D-R Airence" author="CeesK" name="airence">
-<page type="in">
<button name="PLAY" bit="0x37" deck="3"/>
<button name="PLAY" bit="0x34" deck="1"/>
<button name="PLAY" bit="0x3F" deck="2"/>
<button name="PLAY" bit="0x3C" deck="4"/>
</page>
<page type="out"> ... </page>
</device>
and here the mapper:
-<mapper date="16/10/2016" version="800" author="CeesK" device="airence">
<map action="play_pause" value="PLAY"/>
</mapper>
-<page type="in">
</page>
</device>
</mapper>
Posted Sun 16 Oct 16 @ 6:15 pm
It is using the syntax for VDJ7, You need to remake it for VDJ 8. Not to hard, really just a small change in words. And your definition file is small. Not verry dificult. Check out the VDJ wiki.
Posted Mon 17 Oct 16 @ 1:49 am
try to have only one PLAY map in your mapping file. Having 4 of them will probably execute the same action 4 times , so it wont work as expected.
Posted Mon 17 Oct 16 @ 1:43 pm
I've downloaded and install build 3398 because of the netsearch issue in 3432, and surprise....in this build it works!
So, actually I don't have a solution for build 3432, but i'm happy the controller works!
Thank you all for your answers!
Posted Mon 17 Oct 16 @ 6:46 pm
