sorry, what "difficulty" ?
Posted Fri 14 Oct 16 @ 8:53 pm
sorry, was referring to the same issue yammy45 is having. I get a bad hum and also a sort of clicking noise that is in sync with both the jog wheel displays as they are pulsating. I really want to keep the mix track platinum as it is a marked improvement over my idj3 but if I can't get this figured out, I will have no choice. Thanks for any assistance.
Posted Sat 15 Oct 16 @ 8:55 pm
HI can anyone help me im about to purchase the Numark mixtrack platinum but i want to know is virtual dj compatible as i am use to using this software
thanks
thanks
Posted Mon 24 Oct 16 @ 6:21 pm
Posted Mon 24 Oct 16 @ 6:23 pm
thanks
thanks
Numark Mixtrack Platinum is natively supported (Plug 'n Play) in VirtualDJ 8.2
Operation Manual : http://www.virtualdj.com/manuals/hardware/numark/platinum.html
You can give it a try with Home Free for 30 days. After the Trial period, a Pro Infinity, a PLUS or Pro Subscription will be required http://www.virtualdj.com/buy/index.html
Posted Tue 25 Oct 16 @ 2:57 pm
Hello all.. Does anyone know if there is a skin available or is in the works for the Numark Mixtrack Platinum?
Posted Tue 15 Nov 16 @ 9:11 pm
Hello
I would like to purchase the new Mixtrack Platinum.I need some advice from your side.Is it working fine with VDJ 8?Are there any issues with the new Numark?
I read some forums and I can see that the majority of the people are not very please with the functionality of the Platinum.
Can you please help me?
Thank you.
Thank you.
Posted Tue 22 Nov 16 @ 2:06 pm
Cosmyalin wrote :
Hello
Thank you.
Thank you.
Hi ive been using the mixtrack platinum since mid September with vdj 8, i haven't had any issues i think it is a great controller for the price.
Posted Tue 22 Nov 16 @ 4:26 pm
I also had this crack and hum noise
In Settings, go to performance and set UltraLatency to off
This has fixed that horrible noise for me
Posted Fri 25 Nov 16 @ 2:16 pm
djdad wrote :
If Numark doesnt provide a fix, then we will just remove the dimmed off status for the LEDs, but pity such a nice feature - useful when working in dark environments - cant be properly used. Anyways, will keep you updated if anything good comes out of this.
Is there a new update on this? I am about to buy the Platinum, but these humming problems keep me hesitating.
Posted Sat 26 Nov 16 @ 9:50 am
I had that noise, nothing to do with the controller or the LEDS, but ASIO sound drivers.
Turn off Ultra Latency in the performance settings and the noise goes away
Posted Sat 26 Nov 16 @ 11:56 am
Purchased and received my new Mixtrack Platinum and also had the hum issue at first. Then Virtual DJ8 displayed a new version was available for update.. so I closed then opened the software and no more hum!
Posted Wed 30 Nov 16 @ 7:37 pm
Hey guys,
I posted the question on the Numark forums as well, because it's not a Virtual DJ isolated case:
http://community.numark.com/numark/topics/mixtrack-platinum-hum
Posted Fri 02 Dec 16 @ 11:32 am
Hi, i'm about to buy the mixtrack platinum, but i don't know if there is any issue or any trouble with the sftware right now, and also i want to know if i have to buy the premium version of VDJ8 to connect the controller.
Could u help me pls?
Posted Wed 26 Apr 17 @ 2:12 pm
The mixtrack works very well with VDJ.
You do not need to buy full pro, you could get a controller license. It would lock you to that controller though and if you upgrade your controller in the future you would have to buy again. Or you could just pay monthly for full pro.
https://www.virtualdj.com/buy/index.html
Posted Wed 26 Apr 17 @ 2:21 pm
I am having the same humming problem even though I have the latest update? did this get this fixed? please help.
Posted Wed 26 Apr 17 @ 10:55 pm
It's not a VirtualDJ issue, so it's not something we need to fix. We have informed Numark about it and also posted to a related topic in their forums. http://community.numark.com/numark/topics/mixtrack-platinum-continuous-low-droning-sound-hum
Posted Thu 27 Apr 17 @ 12:58 am
Unfortunately I have the same problem with the numark platinum. How can i turn off the led dimming in virtual DJ?
Posted Mon 03 Jul 17 @ 10:50 am
Can you give this a try http://www.virtualdj.com/plugins/index.html?addonid=80621 ?
With this definition, the humm will be reduced or eliminated, but the LEDs will not be dimmed when off
Posted Mon 03 Jul 17 @ 11:46 am
Thank you! All humming disappeared for me!
Its a shame the mixtrack platinum has some hardware failures that makes the led dimming not useable. I love the controller for every other feature!
Posted Mon 03 Jul 17 @ 12:13 pm
