No Early Acess build currently. Build 3398 public build does not fix the screens from what I saw last night
Posted Mon 12 Sep 16 @ 10:03 pm
The build that includes support for the Dashboard screens will be available soon (currently in beta). Will post in Forums when available
Posted Tue 13 Sep 16 @ 5:23 pm
Early Access build 3409 is now available with the Dashboard (and NS7 III update) screens support.
Posted Wed 14 Sep 16 @ 2:31 pm
Can someone please post pics of the Dashboard working with VDJ.
Does it allow the screens to be used as video monitors?
Posted Wed 14 Sep 16 @ 2:49 pm
No video or anything else other to what you have seen on screenshots over the Internet.
The Dashboard screens work similar to the NV screens. It only displays whatever is designed to display and you cant change that.
Posted Wed 14 Sep 16 @ 3:11 pm
I'd consider 3 cheap tablets to be a better idea than the dashboard, similar cost, tablets can do more, less weigh.
Posted Wed 14 Sep 16 @ 3:25 pm
Working now. Thank you!
Posted Wed 14 Sep 16 @ 9:25 pm
Just noticed something. My left deck shows loops and functions as 1/32 - 4 and my right deck has 1/16 - 8. Both displays correctly reflect what the Pad Loop buttons do. I don't have an 8 beat loop for the left side and would prefer it to.
Is this a bug? Can I some how make the Left match the Right?
Posted Wed 14 Sep 16 @ 9:43 pm
Hm i thought i had fixed that , will take a look
Posted Thu 15 Sep 16 @ 9:25 am
Well i took a look at the files and saw nothing wrong, but probably i miss-understood what you wrote.
Indeed the 8 loop boxes on the Dashboard screens reflect to the selected Loop Pads page. If you only get 1/32 to 4, this is because you have Page 1 selected in the Loop Pads, so yu will need either to change that from the skin (the Page arrows will be shown if you hover mouse near the Page name) or from the PARAM < > buttons on the NS7,
Hopefully you are using the factory default mapping or a custom one that has Pads integration.
Posted Thu 15 Sep 16 @ 1:23 pm
Using your 4 deck swap or Fruit skin. I will switch and check tonight. Thanks
I prefer yours, will there be an update?
Posted Thu 15 Sep 16 @ 1:41 pm
Thanks DjDad! I guess I can comfortably order that NS7iii now. My 12% coupon expires today, so great timing!
Posted Thu 15 Sep 16 @ 6:40 pm
@DjDad, wow that was an easy fix and an awesome way to adjust loops to exactly what I wanted. Thanks again for all your help!
Posted Thu 15 Sep 16 @ 11:22 pm
Thank you very much DjDad. I was surprised to see my NS7iii screens working with my last update, as I had not been following the thread. Your work is very much appreciated.
Best!
Best!
Posted Mon 17 Oct 16 @ 12:12 pm
