I am going to re-install Windows 10 Pro on my DJ laptop. I will be doing a clean install after I format the hard drive. Is there a way for me to keep all of my old Virtual DJ 8.1 settings and BPM and scanned songs info, so when I re-install VDJ, everything will still be there? If so, how do I do that? Do I just copy over the Virtual DJ folder in my documents from the old laptop to the new one? Thanks for any help or info!
Brad
Brad
Posted Thu 03 Mar 16 @ 3:30 pm
Hi, I've done this recently.
If you keep a copy of the VirtualDJ folder this should work fine. Specifically you need to make sure you have the database.xml and settings.xml files.
Posted Thu 03 Mar 16 @ 4:25 pm
Strongly advised to have the same Username for your new OS and restore your Music Library with the exact same folder/path structure as you had it in your old computer (in case your Music Library was in the C Drive)
Please see http://www.virtualdj.com/wiki/VirtualDJ8_Backup%20Database_.html and http://www.virtualdj.com/wiki/How%20to%20Transfer%20To%20A%20New%20Computer.html
Posted Fri 04 Mar 16 @ 3:30 am
