Adion wrote :
It is indeed still interesting to find out why performance is worse with the dedicated card though.
Can you try to set videoForceFullScreen to -1 ?
thanks for being attentive, and that is my question, because it works much better with integrated graphics? personally it is not my priority for more than 30 fps video, my videos are in that standard, what bothers me are the jumps and shaking movements of the skin in general that keep me make fine adjustments in the mix,
I will try what you say,
this afternoon or evening recorded a video in full HD at 60fps with my sony actioncam to better appreciate the problem,
a friend dj, pro vdj user also has the same problem
Posted Thu 28 Jan 16 @ 2:53 pm
[quote=camplg]
dedicated Nvidia GT540 graphics, audio only
Campig try these settings: Letter Boxing = Crop.
VideoUserDXVA = Off
VideoMaxmemory = 250
Then go to the 3d graphics control of your computer and select between CPU and GPU, Automatic.
Try these settings out. Also your MaxFps should be 30 in the virtual DJ settings
VideoUserDXVA = Off
Posted Thu 28 Jan 16 @ 4:09 pm
