When is this mixer out in the UK, I see the US has it, but as yet I still have not been contacted to say it is coming.
Posted Thu 05 Nov 15 @ 12:02 pm
Well you can always guarantee two things with Pioneer in the UK ..... their gear will be late and very expensive!
Communication from them is zero then one day it will magically appear!
Posted Thu 05 Nov 15 @ 12:05 pm
Mixer arrived, drivers wont load on PC and Serato will not activate on mac, cant post on serato forum for some reason, living the dream.
Posted Fri 13 Nov 15 @ 12:25 am
Oh boy. Always something. Hopefully something simple that is.
Posted Fri 13 Nov 15 @ 1:49 am
Following, any more news on this? Should I look in other threads? Didn't know if there was an official topic for the Pioneer DJM S9 and Virtual DJ, thanks.
Karz
Karz
Posted Tue 01 Dec 15 @ 2:22 am
Pioneer has very recently released MIDI data for the S9, so we could come up with mapping files.
We will need your help on this.
- Install the necessary drivers for the DJM-S9.
- Open VirtualDJ and head to the OPTIONS tab of the Settings window.
- Enable the "Show Advanced Options" and search for the setting "CreateMidilog"
- Set it to Yes and close VirtualDJ 8.
- Make sure the DJM-S9 is connected and powered on (preferrably no other MIDI controller at that time)
- Open VirtualDJ and close it again right after (no need to do anything else)
- Post here the content of the Log Report.txt file you will find in Documents/VirtualDJ folder.
It would also help if you could try to create an audio configuration with the DJM-S9.
Most likely it should be ..
Deck 1 .... Pioneer DJM-S9 ASIO .. chans 1,2
Deck 2 ... Pioneer DJM-S9 ASIO ..chans 3,4
but it could be different. Let us know which audio setup works with this unit or post a screenshot here.
Thanks
Thanks
Posted Tue 01 Dec 15 @ 12:28 pm
Updated windows and the drivers worked, not had chance to use mixer yet sort Serato out, however Serato support has been great.
Posted Tue 01 Dec 15 @ 8:18 pm
Charlie, you have mentioned this twice in this thread. How does this working with Serato, or great Serato support, help the Virtual DJ user? If you want to help the Serato users, why not use their forum?
Posted Tue 01 Dec 15 @ 9:05 pm
--- 2015/12/04 - 15:50 (2587)
[15:19] Midi Out Closed (Microsoft GS Wavetable Synth)
[15:19] Midi Out Closed (\\?\usb#vid_2b73&pid_000b&mi_01#7&fb1a6f9&2&0001#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\global)
Audio device found: name="High Definition Audio Device" vid="0x10EC" pid="0x0233" hardwareID:"{0.0.0.00000000}.{2e68e0b7-5250-4b5a-bfc0-d55b14c50700}"
Audio device found: name="PIONEER DJ DJM-S9" vid="0x2B73" pid="0x000B" hardwareID:"{0.0.0.00000000}.{c7aecb37-9f6a-46d7-94b7-b382d8ebcf8b}"
Audio device found: input name="PIONEER DJ DJM-S9" vid="0x2B73" pid="0x000B" hardwareID:"{0.0.1.00000000}.{3c1b2df9-357f-4619-bec5-13c96ff5a202}"
Audio device found: input name="High Definition Audio Device" vid="0x10EC" pid="0x0233" hardwareID:"{0.0.1.00000000}.{84268b23-2257-4bae-ba7e-c9fc460f6c17}"
Audio device found: asio="NS7 II USB Audio Device" hardwareID:"2240292B-D6A2-470E-A0C1F9A14F837B41"
Audio device found: asio="Pioneer CDJ ASIO" hardwareID:"28032B99-BCB8-4843-B9C6C300BD6F80BA"
Audio device found: asio="PIONEER DJ DJM-S9 ASIO" hardwareID:"A7D2434D-77DD-4E2B-993632A1EF27E97B"
Midi out device detected, name:Microsoft GS Wavetable Synth mid:1 pid:27
MIDI Device Identifying: \\?\usb#vid_2b73&pid_000b&mi_01#7&fb1a6f9&2&0001#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\global (in:0 out:1)
MIDI Device Identified by general midi: \\?\usb#vid_2b73&pid_000b&mi_01#7&fb1a6f9&2&0001#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\global
MIDI Device Identifying: Microsoft GS Wavetable Synth (in:-1 out:0)
[15:24] Midi Out Closed (Microsoft GS Wavetable Synth)
MIDI Device Not Identified: Microsoft GS Wavetable Synth
Posted Fri 04 Dec 15 @ 10:27 am
@djdad
Hope this helps. (Posted log file above)
Remember me? I had the problem with terminal mix 4. I gave up on it lol. Now went and bought the s9 and need the midi mapping ASAP please!!!
Cheers
Cheers
Posted Fri 04 Dec 15 @ 10:29 am
Here is the screen shot of the s9 settings.
I installed the driver from pioneer site and then restarted windows. Selected external mixer and it works. Also put timecode in there.
Posted Fri 04 Dec 15 @ 10:32 am
Sorry it didnt upload last time
Posted Fri 04 Dec 15 @ 10:33 am
Cool thanks for the feedback and info. Will prepare some testing mapping files and send you for testing.
Posted Fri 04 Dec 15 @ 4:49 pm
Can you also click on the ASIO button you see in the Audio configuration of VirtualDJ (right next to the descirption of the sound card) and post some screenshots of the ASIO Utiltity of Pioneer (all tabs if possible).. Thanks
EDIT. Never mind, found those from the manual.
Posted Fri 04 Dec 15 @ 5:56 pm
If anyone else (except prasanf who is already in my list) wants to try some preliminary mapping files, please either post here or PM me.
Posted Fri 04 Dec 15 @ 8:24 pm
Thank you sir! Cannot wait. :)
Posted Fri 04 Dec 15 @ 8:57 pm
saw the preview of the s9 & was impressed...top of the line mixers don't come cheap...maybe saving for one in the future
Posted Sun 06 Dec 15 @ 2:31 pm
@djdad,
Was wondering if you were able to create the midi definition file yet? If u could share that with me I would be very thankful as I want to do a bit of somple mapping for the LED lights on the buttons.
Also take a look at the behaviour of the crossfader. It sends out 6 signals. Is that normal? I can't seem to get it to work with the simple midi wrapper.
Cheers boss.
Cheers boss.
Posted Tue 08 Dec 15 @ 3:01 am
Hi the crossfader is sorted now.
But I can't understand how to get LED lights to work (this is by first time doing custom mapping). If you or anyone could please help me out with a snippet of code to use for this mixer I would be grateful. The midi code list is here - the list of MIDI messages http://cdn.pioneerdj.com/-/media/pioneerdj/downloads/midi-mapping/djm-s9/djm-s9_list_of_midi_message_e.pdf?la=en
prasanf wrote :
@djdad,
Cheers boss.
Cheers boss.
Posted Tue 08 Dec 15 @ 8:01 am
So I have done a half decent mapping for the S9 and a midi wrapper.
I'm trying to share it here but seems u can only share images.
Posted Wed 09 Dec 15 @ 7:37 pm
