Forum: Old versions
Topic: NS7 III Compatibility? - Page: 5
DJadamt wrote :
Got it all working now :) bit glitchly but I understand its only a bata so was expected but I find it skips a lot, manly when uploading up new tracks or when 2 tracks are playing at same time
The amount of data sent/received from the NS7III (due to platters and screens mostly) is considered a big loan for the USB buffer, therefore sound issues may occur. It is advised to use a strong spec and well-optimized computer
DJadamt wrote :
also would it be posible to get the mapper done for the use with version 7 I'm still getting used to 8 so tend to use 7 more even if it means losing the screen feature that's fine just as long as I have the controller working
Even if the mainboard of the NS7III can be mapped to operate with version 7, the screens will not be able to follow. Version 7 has stopped been developed so a native mapping for the NS7III in ver 7 will not happen.
djdad wrote :
If anyone gets a NS7III or even just the screens , please contact me.
Just got the ns7iii has anyone gotten the screens working yet??
jaz69 wrote :
[quote=djdad]If anyone gets a NS7III or even just the screens , please contact me.
Working. Screens still not perfect.
Can you provide more details about whats not working properly for the screens ?
What if I buy the Screens only and want to use them with my Pioneer DDJ SZ ? Is this possible?
i bought my ns7iii and i love working with virtual dj and i want to keep on working with virtual dj, but is it working now with virtual and what is the percentage 0 out of 10 ?
Ok got the add on screens going with the NS7 ll and Virtual DJ I've seen no issues with the 3rd deck waveform displaying in the middle deck it did however took me a while to figure out how to map the browser knob but it's all said and done now and I love it thanks a lot Virtual DJ y'all are the best!!!!!
Are you gonna list your mapper for it also
dj2bucs wrote :
Are you gonna list your mapper for it also Kinglee
I can't the screens to show after installing the Beta Update
Please help someone
Please remove any NS7III related files from both /Devices and /Mappers folders and relaunch VirtualDJ. the mapping files are now implemented inside the core application.
BTW, do you have the NS7III or the NS7II+screens ?
Ns7 3
If you delete the mentioned files , open VirtualDJ 8 and then goto the Controllers tab, you should see all 3 devices at the top-left and each one (if clicked) should offer a "factory default" Mapping on the right side.
Is this the case for you ?
Also check if the Displays are not assigned to the correct decks (Left to 1,3 and Right to 2,4).
If none of the above happens, please provide us the Log Report.txt file , generated in /VirtualDJ folder if you..
- open VirtualDJ, goto Settings-->OPTIONS tab.
- Enable the setting createMidilog
- Close VirtualDJ.
- Open again, and then close again.
Post here the content of the Log Report.txt file
- Close VirtualDJ.
The Screen are offering only an Automatic option, not factory default
ok please look at the instructions above and provide the content of the Log Report.txt file.
Keep also in mind that you need to use the latest Early Access build 3268 of VirtualDJ 8.2
Where do i find the log now?
420071345 : License expired on 0
--- 2016/06/20 - 10:36 (2844)
USB MIDI device: vid:0x0480 pid:0x0101 usbName:External USB 3.0 vendorName:TOSHIBA serialNumber:20150217012572F
USB MIDI device: vid:0x0409 pid:0x005A usbName: vendorName: serialNumber:
USB MIDI device: vid:0x15E4 pid:0x0037 usbName:NS7 III vendorName:Numark serialNumber:
USB MIDI device: vid:0x15E4 pid:0x0039 usbName:Dashboard Left vendorName:Numark serialNumber:
USB MIDI device: vid:0x15E4 pid:0x1039 usbName:Dashboard Right vendorName:Numark serialNumber:
Midi in device detected: \\?\usb#VID_15E4&PID_0037/337903616
Midi device: name:Dashboard Right manufacturer:Numark model:Dashboard Right
Midi in device detected: Dashboard Right
Midi device: name:Dashboard Left manufacturer:Numark model:Dashboard Left
Midi in device detected: Dashboard Left
Midi out device detected: Dashboard Left
Audio device found: name:Built-in Microph hardwareID:"44"
Audio device found: name:Built-in Output hardwareID:"51"
Audio device found: name:NS7 III vid="0x15E4" pid="0x0037" hardwareID:"61"
MIDI Device Identifying: \\?\usb#VID_15E4&PID_0037/337903616 (in:0 out:0)
MIDI Device Identified by PID/VID: \\?\usb#VID_15E4&PID_0037/337903616 : Numark NS7 III
Assigned Numark NS7 III, type:0, index:1
MIDI Device Identifying: Dashboard Right (in:1 out:1)
(trying to match sysex for Dashboard Right : found F07E00060200013F39001908080202107F7F7F7F4E313135313231383639303333333700F7F07E00060200013F39)
MIDI Device Identified by general midi: Dashboard Right
MIDI Device Identifying: Dashboard Left (in:2 out:2)
(trying to match sysex for Dashboard Left : found F07E00060200013F39001908080202007F7F7F7F4E313135313231383639303333333700F7F07E00060200013F39)
MIDI Device Identified by general midi: Dashboard Left
HID Device found, looking for definition. \\?\hid#VID_05AC&PID_0259/339738624
(trying to match sysex for Dashboard Left : found F07E00060200013F39001908080202007F7F7F7F4E313135313231383639303333333700F7F07E00060200013F39001908080202007F7F7F7F4E313135313231383639303333333700F7)
--- 2016/06/20 - 10:37 (2844)
--- 2016/06/20 - 10:38 (2844)
Pretty sure I did that too many times
71%
