dear all
i use the consule Hercules 4mx and i use the skin of thie consule.
it has 12 slots but still when one effect is working and i operate another one it automaticly turn off the first effect.
it something that i didn't have in the virtualpro 7 and it worked vey good with the consule.
mybe there is smothong in the Settings that i need to change in order to operate few effects togather?
please advise
thanks
almog
Posted Mon 06 Apr 15 @ 9:20 am
how have you mapped the buttons to trigger Effects ?
Are you using the djc_button actions or some others ?
Posted Mon 06 Apr 15 @ 9:38 am
i use the consule mapping like i did in virtualpro 7.
i use the djc_buttons in the consule and i compare it to the same setting i had in the consule wehen i worked with the virtual pro 7.
Posted Mon 06 Apr 15 @ 10:12 am
almog21377 wrote :
dear all
please advise
thanks
almog
dear all
please advise
thanks
almog
Posted Wed 08 Apr 15 @ 8:45 am
You dont have to quote your own post. Issue has been reported to Dev Team.
Posted Wed 08 Apr 15 @ 10:40 am
