Forum: Beta Builds Regression Bugs
Topic: BUILD 2171 - Page: 2
But did you try to load both while the first is still preloading ?
No, I don't do that. It's not good practice.
[tries the bad habit] Yes, if I do that the songpos is flat and VDJ crashes.
Solution = don't do that! :-)
Me either, I just did it to confirm the crash :)
I'm still getting the bug with 2171 :
Also, there's now a strange behavior when switching :
- menu deck / wheel / art
The cover is not showing correctly (it is supposed to show over the songpos ring).
Note: The mask problem happened only once. After relaunching the software I can't seem to be able to repoduce. But stills, the option I described is bugging now (it shows some artifacts all along the songpos ring and the words now appear in red instead of white (when there's no cover to show). The cover picture is 'red-ified' too, on both decks).
Hi Fruit,
The clipmasks for your rotating covers are currently transparent with coloured circles; they should be black/white masks :)
Regards,
Scott
Mm, actually it's a feature, to shade some parts of the cover (for the 'art' option mainly).
PachN wrote :
DJ SWID wrote :
Look what happens if you load the same song in both decks
Same with some some..OSX 10.9.2 / 2.6Ghz i7/ 8Gb RAM
you dont have to quote the same posts. Bug is spotted from the Dev Team and probably fixed for the next build.
