Forum: Beta Builds Regression Bugs
Topic: BUILD 2117 - Page: 3
i use the Turnado from the begining of V8 without any issue but after some Updates i have this issue.
i try everything nothing helps only if i remove Turnado.ini the effect load with correct Setting. but when i close and open vdj i have my wrong Settings back (restored).
[autoparams] Wrong Settings
Slider Control 1 0=0
Slider Control 2 1=98
Slider Control 3 2=0
Slider Control 4 3=0
Slider Control 5 4=0
Slider Control 6 5=638
Slider Control 7 6=0
Slider Control 8 7=1761
[autoparams] Right Settings
Slider Control 1 0=471
Slider Control 2 1=0
Slider Control 6 5=0
Slider Control 8 7=1863
If i change the Settings in VDJ and close it in Turnado.ini are the right Settings but after vdj start & close i have the wrong Settings back in Turnado.ini.
Trust me it's not a regression bug, I ran into the very same problem about 2 months into V8, for 2 months it was fine then V8 wouldn't remember certain FX settings, the problem was I had the FX on the master slot, so when I changed the settings on a deck they didn't stick
Here's a test. Rename settings.xml, start V8 open one instance of turnado, change the settings wildly, close V8, re open V8, the settings will have stuck
