Simply make a sidelist shortcut into automix mode.
There are times when a client wants specific music played at cocktail hour or dinner or any other part of the night and would like to make a sidelist shortcut into automix.
Please add that feature.
Posted Wed 17 Dec 14 @ 11:06 am
Maybe the action "switch_sidelist_playlist" is what you are looking for.
Posted Fri 19 Dec 14 @ 4:29 am
That doesn't switch a shortcut.
Posted Fri 19 Dec 14 @ 7:38 am
Then I don't get what you want :-/
Posted Fri 19 Dec 14 @ 9:01 am
Turn a shortcut into automix. Can't explain it any simpler than that.
Posted Fri 19 Dec 14 @ 9:17 am
Are you looking to dump the sidelist into the automix list and start the list auto mixing all via a button or key?
Mapping the above script from PachN should move the list, then just add the starting of automix after that.
Or just open a saved playlist/smart folder, select the contents, and drag it into the automix.
Posted Mon 22 Dec 14 @ 1:11 am
Select all the tracks in the sidelist, drag them down to the button to switch to automix, hover there for a second = profit
Posted Mon 22 Dec 14 @ 1:59 am
Doesn't work.
Posted Mon 22 Dec 14 @ 7:03 am
it does in 2094
select the tracks in side list , drag down to the automix shortcut and hold it there for literally 1 second, it switches to automix, it also works for all the other shortcuts.
Posted Mon 22 Dec 14 @ 7:20 am
It works only when you select a few tracks... not the entire list. I tried it on Mac and PC.
Posted Mon 22 Dec 14 @ 8:50 am
Well we're improving 2 hours ago it didn't work, Try again, I just managed with 982 tracks.
Posted Mon 22 Dec 14 @ 8:53 am
Was it all of the tracks that were in your shortcut??I try to select all and drag to automix and they do not appear at all. I select all except for one and they appear minus the one i didn't select.
Am i the only one that thinks this is useful?
Posted Mon 22 Dec 14 @ 8:59 am
If it's that vital use the horizontal side list and bug report it what you've found
Posted Mon 22 Dec 14 @ 9:27 am
I reported it to Max but it doesn't seem to have been fixed.
I was told to add my request to the Wishes and new features.
Posted bug here... http://www.virtualdj.com/forums/196820/VirtualDJ_8_bug-report_Forum/Dragging_shortcut_playlist_to_automix.html
Posted Mon 22 Dec 14 @ 9:46 am
It seems it has to deal with file formats. I answered in your bug thread.
Posted Mon 22 Dec 14 @ 11:12 am
They're all mp3s.
Posted Mon 22 Dec 14 @ 11:51 am
Just to clarify what DJ Koz is asking for here:
In the normal folder view (the left side of the browser) you can right click on a folder and select 'Load in AutoMix'.
However, there is no such option for the folder shortcuts which can be added to the bottom of the sidelist. Ideally these shortcuts should behave exactly the same as normal folders, with a right click option to 'Load in AutoMix'.
Posted Mon 22 Dec 14 @ 2:27 pm
Groovin...
From a shortcut sidelist you can drag the contents from it to the automix shortcut button and it should load the files into automix. It kinda works but not when you select all the files at once.
Posted Mon 22 Dec 14 @ 2:30 pm
An option to load in to automix would be ideal.
Posted Mon 22 Dec 14 @ 5:54 pm
When in automix mode, click the got on the right side, the drop menu appears, click save, thats how you save your playlist. VDJ8 did make things more complicated than 7. I had to ask tech support how to save a playlist.
Posted Fri 26 Dec 14 @ 7:56 pm
