-Slideshow has option to play video
-Midi clock output setting stored in config
-Fix utf-8 titles not correctly truncated in status message
-Delete available for samples in search too
-File operations not performed on db when failed
-Fix some browser touch screen issues
-Fix sideview shortcuts with ' in their name
-Fix effect_select +1 sometimes lighting up
-Midi jog wheels that use 'inverted' note fixed
-Fix video edits with only image added not displaying as video
-Fix flickering in video editor preview
-Fix file deletion crash on Mac OS X 10.7
Posted Wed 26 Nov 14 @ 7:23 am
Global variables still being erased from settings.xml after auto updating.
Posted Wed 26 Nov 14 @ 7:39 am
@ groovin Persistent variables, not global. @ !$
Posted Wed 26 Nov 14 @ 8:00 am
Well they're called global variables in the XML file! :-P
<VDJScriptGlobalVariables>
Posted Wed 26 Nov 14 @ 9:18 am
slidershow video,,, cause accident on mac......
Posted Wed 26 Nov 14 @ 9:53 am
Did a up date now VDj will not open..
Posted Wed 26 Nov 14 @ 10:02 am
It crashes here too, as soon as the Video button is pressed and the Slideshow is enabled.
Posted Wed 26 Nov 14 @ 10:25 am
Still notice a clicking/static noise on the sampler,
Just try with the "Hard Kick" from the default Instrument and play mp4 videos..on PC :-(
Posted Wed 26 Nov 14 @ 10:45 am
"Fix file deletion crash on Mac OS X 10.7" - confirmed! the issue with VDJ8 freeze+Lag also gone, thank you so much Atomix!
analyzing tracks process takes too much CPU, causing distortion/stutter on OSX 10.7 (this does not happen on win7 or build1845 osx 10.7)
cloning decks still not fixed for motorized platters, works ok with players without motor (cloned deck is 1/2 beat behind original track; duplicating the clone deck action and works fine), also cloning decks does not copy cue point or loops
saved loops bug still happens (load a track with a saved loop(at end of track), arm that loop, so the track doesnt stop playing at end, play the track from beggining,then if I touch/hold the vinyl the track jumps right to the armed loop at the end, pitchbending using the platter or even scratch forward(forward spin) its fine,only if I stop/hold the vinyl or backspin the track jumps to the armed loop. I dont think its suppose to work this way...)
looking forward
thank you
looking forward
thank you
Posted Wed 26 Nov 14 @ 1:23 pm
-Slideshow
Before, when you have the VideoAudioOnlyVisualization set to Slideshow, and added new pics to the folder, it does NOT show the NEWLY ADDED pics at all.
Now it works perfectly... Thanks to the TEAM.
(I'm playing around with the new option (playing video). I can't get to work. I was using a MP4 file. But I don't think I will use this for slideshow anyway.
My main thing was the Pictures showing during Audio playing.
Thanks.
P.S. Could someone add FADE. I use this 100% everytime. According in the info, it was made by clax ????
Now that the Slideshow works the way I use it, I may go Live with V8.
Thanks Team.
Thanks.
Thanks Team.
Posted Wed 26 Nov 14 @ 1:25 pm
The Magic.DJ wrote :
(I'm playing around with the new option (playing video). I can't get to work. I was using a MP4 file. .
Have you enabled the VIDEO effect button from the FX GUI ? Speed slider to max and fade slider to 0 ?
Posted Wed 26 Nov 14 @ 1:29 pm
Thank you
Thank you
Posted Wed 26 Nov 14 @ 1:34 pm
thanks DJDad.
Got it to work. It did crash on me (should have a dump on VDJ server). This happened when I was fiddling with the 2 setting (fade/speed).
Anyway, I use this mainly to display pictures.
The video portion can be useful in some other setups.
Thanks.
Thanks.
Posted Wed 26 Nov 14 @ 2:12 pm
2064 will not load can't open vdj8 after the up date..need to use over the H-day weekN
OSX 10.9.2 / 2.6Ghz i7/ 8Gb RAM
Posted Wed 26 Nov 14 @ 2:26 pm
In which case I would recommend you revert to the public build rather than a beta build.
Posted Wed 26 Nov 14 @ 2:30 pm
try re-install,I have had similar problems with auto updates on other builds
virtualdj.com/download/virtualdj8/mac/2064
virtualdj.com/download/virtualdj8/mac/2059
Posted Wed 26 Nov 14 @ 6:13 pm
The ability to drag and drop "Live Feedback" suggestions to a deck no longer works with build 2064.
Posted Wed 26 Nov 14 @ 9:45 pm
works fine here. What files are those ? Audio, Video ? Did you try to cache them and see if those are unavailable ?
Posted Wed 26 Nov 14 @ 9:54 pm
This doesn't work for all suggestions, it depends on availability of the suggestion with the services you subscribed to.
Posted Wed 26 Nov 14 @ 11:06 pm
Image&Video sawtooth
Unable to adjust the size
Posted Thu 27 Nov 14 @ 1:04 am
