Hi all I 'm using virtual 8 build 2048,868 and there is a problem I have the pioneer sx2 when selecting the slicer mode is turned off or put in loop mode the audio and return must press a pad or selected hot cue , roll or sampler mode.
There is a fault that should hopefully help me thanks .
Posted Tue 18 Nov 14 @ 7:45 am
20yr in the club and the last 8yr using Dj S.W,but in the Dj booth I use fans/computer fan now doing private gigs the fan was not need more room,but the last update made my computer fan run more then usual with controller now plug in,or maybe it just me.The temperature is cold here were I'm at now but come summer this may be a issue with the fan Now running with VDj-8 2048,7 was ok. (mac)
Posted Tue 18 Nov 14 @ 8:12 am
djdad wrote :
For controllers with Slicer & Loop Roll Mode Pads, please check again with 2048.870
How to get this .870? I tried running the software with my system online and controller (SR) attached but can't get any update to .870.
I'm stuck on .868 with a problem of roll not activating / not functioning after doing slicer.
Posted Tue 18 Nov 14 @ 11:27 am
According to hardware support the controller db auto update is currently broken, so this won't be fixed until the next build.
Keith
Keith
Posted Tue 18 Nov 14 @ 11:36 am
I also had the Slicer problems above,on my SCS1d costum mapping, but didnt know it was a bug,so created a script on the loop roll midi key to turn off the slicer fx.
Just finished win 7 bootcamp,having some issues with tracks stoping every 7/8 seconds...but I think it is drivers related idk...looking for a solution...I hate windows....
B2048 pc: the scratchwave drift also happens on win7,with pitchquality at 1,but no drift at 2 or 0; the cpu meter goes up and down, but the sound isnt affected ,will have to solve my tracks stopping issue to do some more testing...
Posted Tue 18 Nov 14 @ 12:28 pm
The track is actually stopping? or its pausing on the display and the music is still playing?
Posted Tue 18 Nov 14 @ 12:40 pm
track pauses then keeps playing after 1 sec or 2,like I just holded the vinyl, happens every 7/8 seconds using the SCS1m soundboard, if I use my NI A2DJ it does the same but every 30secs...
Posted Tue 18 Nov 14 @ 12:46 pm
You should use either DPC Latency Checker or LatencyMon to check your system for problems caused by drivers etc.
Posted Tue 18 Nov 14 @ 12:50 pm
i wonder if windows search is using cpu indexing your music (like indexing in spotlight) when youre in Vdj and not playing any music is the cpu going up and down?
TIMECODE VINYL
I am having the same issue like vdj partyboy but i am using windows 8/ i7 /16ram when i do some heavy scratching it like i lose the scratch a little bit i can not call it I thought i fix it by Putin pitch quality ON 0 with master tempo on but on that setting i get a lot of Static so i try it with 1 & 2 no master tempo it worst with master tempo on and pitch quality on 2 its a little better but still lose the scratch when i do heavy scratching i try it with SERATO SL3 BOX and the HERCULES RMX 2 same thing happen.timecode need to be more sharper like in built 2003 before u can see the serato box in audio config. DEV need help please.
Posted Tue 18 Nov 14 @ 12:54 pm
Hi, Using build 2048.868
updated yesterday, i have the same problem other users have reported, when loading a track and pressing the slicer mode, the audio drops out, the waveform keep scrolling as if the track is still playing.
No audio can be heard., or the other fault i get is when pressing Slicer mode the track goes into an automatic loop, when pressing hot cur or roll, the loop will stop, if i press the slicer mode the loop will restart. It will only stop if i hit a pad when in slicer mode. its messy at the moment, i cant trust it. I have radio shows that i do daily. How can i roll back to a previous version. It's rendering virtual DJ unusable at the moment. How do i rollback to a previous version that was solid for me pls.
Posted Tue 18 Nov 14 @ 1:13 pm
https://virtualdj.com/forums/193007/Beta_Builds_Regression_Bugs/how_to_download_previous_builds.html
Posted Tue 18 Nov 14 @ 1:17 pm
As stated above, the DB is stuck at .868 as the auto update is broken in this build. We can't get .870 at present. According to Babis this can't be fixed until the next beta version is released. The current controller version as of this morning is .876
I'm not sure if rolling back the software version will put back an old controller DB file which is where the issue is. This is a beta release so you shouldn't be installing this on your working machine as they can cause problems like the one at the moment!
Keith
fireyute wrote :
How do i rollback to a previous version that was solid for me pls. It's rendering virtual DJ unusable at the moment
Keith
Posted Tue 18 Nov 14 @ 1:26 pm
I think its more a server issue/bug, not a software one. Hope it will be addressed soon.
Posted Tue 18 Nov 14 @ 1:38 pm
Thank you :)
Posted Tue 18 Nov 14 @ 1:59 pm
ok, thanks..hope the issues get sorted soon
Posted Tue 18 Nov 14 @ 4:11 pm
mapping for the PFL "cue / master" fader knob is not working in this build on pioneer ddj-ergo
Posted Tue 18 Nov 14 @ 5:12 pm
Will be fixed in next controllers version .xxx (last 3 digits).. related to the server bug as described above.
Posted Tue 18 Nov 14 @ 5:22 pm
Video is not showing up in the projector output in this build. I tried V7 and the video is showing up. It is showing on previous builds..
Posted Tue 18 Nov 14 @ 7:07 pm
must be just you... since I did a complete video gig with this build just yesterday...
maybe a setting you missed?
Posted Wed 19 Nov 14 @ 11:39 am
