I have 80 buttons mapped and working in 7 all effects and every thing. The second I try to use it in 8 the led have a conflict and go sideways. I have double checked the pid and sysex and all the rest . I am confused. any help would be always welcome.
Posted Thu 14 Aug 14 @ 11:47 am
You will have to be more specific. Which controller do you use ?
How are the Leds defined in the definition if the unit is not natively supported ?
How are those Leds mapped ?
Posted Thu 14 Aug 14 @ 12:40 pm
ok , I have a apc 20 and a apc 40 . Both of them work perfect in version 7 and all the led respond as mapped. In version 8 the led are not working right some not at all. I don't get it.
Posted Fri 15 Aug 14 @ 11:25 am
