so far, fine, no problem, just waiting solving equalizers ...
Posted Mon 18 Aug 14 @ 7:59 am
Very big problem that I believe needs to be fixed ASAP , because most of us DJ's you this function at weddings , when were all having dinner music playing
When all the songs are in Automix , ( On Auto pilot ) when the track is about to end , there is a loud noise before hitting the next track , sounds like your taking a needle off the record , and these reports are also coming from other DJS not just me .
Windows 7 64 bit
Windows 7 64 bit
Posted Mon 18 Aug 14 @ 12:10 pm
TIMECODE HELP
who can i speak to that deal with TIMECODE VINYL issue from the dev team?
Posted Mon 18 Aug 14 @ 1:28 pm
@ pumpitentertainment
Try setting pitchquality to "1" ;-) You can find it under "Performances.....
Posted Mon 18 Aug 14 @ 1:38 pm
Got a Crash but it was not in the VDJ Crashguard report,so I copy before reopen and paste it in,do I need to send to this forum or just delete it ?
Posted Mon 18 Aug 14 @ 8:03 pm
still getting random screen hangups. couldnt say exactly which build this has been happening from, but some gigs it happens 5 times and sometimes not at all..
last gig it happened just as i pressed play on the next track resulting in the skin "greyed out" and silence as was unable to start the track...
Posted Tue 19 Aug 14 @ 6:59 am
That seems to have fixed it thank you !
Posted Tue 19 Aug 14 @ 11:33 am
It is effect on pitch quality!!!! :(. The time streach is bad when I choose 1 on it. They need to fix it!!! Automix mode have bad sound when mixing its should be fix .
Posted Tue 19 Aug 14 @ 3:01 pm
I found solution . Latency = 512 !!.
Works greats for me.
Before my setup was latency = 1024.
Now its sound great!!
Posted Tue 19 Aug 14 @ 3:41 pm
OK guys, small request - please cool it with the inclusion of a massive screenshot of your system specs. I've removed two on this page as neither seemed particularly relevant to the actual post.
It's also easier just to insert a line of text containing the relevant specifications.
Posted Tue 19 Aug 14 @ 9:17 pm
This Build! MAC User
the order of the time history is wrong, now...
Posted Wed 20 Aug 14 @ 3:06 am
