Forum: Beta Builds Regression Bugs
Topic: Build 1878 - Page: 3
I don't want to keep repeating myself but can we please work out that bug with the numark ns7 ii as to to where I load a track in one deck the other stops and speeds up I was a serato user and decided to try vdj 8 and I love it . I, M on a subscription right now and I really want to buy the full version but I, m very conscious as to if this problem will be solved. Thanks in advance.
I tried to recording a pre-set for the local radio station with VDJ-8 and there is a 12-15 second delay in sound in play back..
Bonjour (French)
A - Crash with custom button.
Condition:
- Windows 8.1, Icore 7, 8 Go RAM
- Controller Behringer CMD Studio 4a
When i press a Load FX1 or 2 button on my controller:
Sorry the next story
When you wait that is a blue screen and restart computer (it is my first blue screen on Windows 8.1)
The reason is on mapping
All of my custom button are in the default configuration (nothing)
B - Can you memorise the size of the tag editor (Width) for all non US user. The translate is long that US.
C - It is possible to change the Birate off Recording in MP3 (actualy 192 Kbps)
version, not presented any problem to me, but it has the following flaws:
# White flasheos on skin
# You can not drag files from the outside in the soft
# Bpm engine reads bending values
if deck 2 is not played action effect "vinylbrake" active not working !!!!
