I am having a heck of time trying to map my RMX2 with virtual DJ 8, i also have a 4MX that I may need mapping help with as well. Any help or assistance would be greatly appreciated.
Posted Fri 20 Jun 14 @ 5:27 pm
Both units are natively supported and should be properly detected and offer a "factory default" option in the Mappings field (Config->COntrollers tab)
If you need to customize the mapper, and assign different actions than the default ones, feel free to post here anything that would like assistance with.
Posted Fri 20 Jun 14 @ 5:40 pm
I wonder how to get the Balance on the skin, using the RMX.
Currently when turning the Balance button to the Left or to the Right there is no visualization with it.
Would be nice to see that as well, to know if it is correctly in the middle or not.
Posted Sat 21 Jun 14 @ 4:48 am
I have a similar question with how to change the default effects mapped to the effect pads. I want to change a few of them to new ones I downloaded. Appreciate the help!
Posted Tue 22 Jul 14 @ 11:42 pm
