Topic: 1828 - BETA Build - Page: 2
Thanks RobRoy .
Thanks Jakouski.
Hate to say but I'm still not getting the 1828 version.
1828 is currently in Beta.
If you have beta builds selected in advanced config of VDJ then you should get it. Otherwise you won't.
Any way to find out what is been tested in 1828, obviously other than being able to download it.
Haha, (Sorry, you don't have the necessary accreditations to view this page.) I'm still a leper, no worries...
edit, (19:53) realised after I got called away I'd need to enable access, I'm such a dumb smuck!
I have had beta builds enabled since last week (or earlier) and nothing has changed with me getting any beta builds. I have access to the regression testing thread but no S/W to test,
.... I'm such a dumb smuck!
And now he realizes it....:>
