try with this effect: echo doppler
Posted Mon 21 Jul 14 @ 10:08 pm
but once you load another track it cuts off....
Posted Tue 22 Jul 14 @ 2:19 am
Even if you set "resetFXOnLoad" to off (or no)?
Posted Tue 22 Jul 14 @ 3:18 am
not for me it doesnt, just double checked and it keeps echoing after i load another track on the same deck as the fx. .... i used echodoppler
Posted Tue 22 Jul 14 @ 7:55 am
Keeps going for me too with FX reset set to off.
Posted Tue 22 Jul 14 @ 10:44 am
Im gonna do a video since no one seems to understand th advantange of post fader effect in your mix. And why i say it cuts off .
Posted Tue 22 Jul 14 @ 11:58 am
Posted Tue 22 Jul 14 @ 11:59 am
Echo Doppler.............. or use an external mixer with onboard effects.
As much as I hate saying it, we probably aren't going to see post fader effects with VDJ anytime soon. This was a complete rewrite and they didn't get added plus the fact that our effects our user based. I really don't see it happening.
All these work arounds just won't cut it for my since 90% of my gigs are video which is why I went with a mixer that has its own effects.......
Good Luck.
Good Luck.
Posted Tue 22 Jul 14 @ 12:10 pm
The only thing that is different with VDJ's echo is once you turn it off you WILL loose the tail so your gonna have to be creative in how you mix in the next track.
Posted Tue 22 Jul 14 @ 2:27 pm
