Topic: post fader FX - Page: 13
locodog wrote :
What's needed is pfl pre fx, another user asked me about the very same issue.
but higher on the drawing board I'd rather see a re routing fx, that passes the sound up the chain but also to another output source.
I'm with you bro but I'm not even sure if these guys are even up to snuff anymore. It's really time to step there game up. Adding script and a new transition just ain't gonna cut it anymore.
It might be fine for the newbies but as a professional working DJ this is getting old. Even there attitude has seemed to of changed for the worse anymore......
Hopefully someone can respond or let us know something.......
cross DJ have standart post fader fx , where problem in virtual dj .
every mixers from pioneer have post fader fx .. great disappointment in V8
Your welcome to the fight!!!!
Anyone know hot to get the slider working in 4 deck skins? 4 decks XML is missing the "<define class="volume_level" classdeck="left" action="level" rightclick="temporary" orientation="vertical">" lines.
Which slider? Which skin?
Silversleek2 it uses a 4 deck XML much like the 4 deck XML in the default VDJ8 skin there is no simple 2 deck to edit like the Volume plug author has described.
EDIT: The author of the post fader effect plugin says to change the lines to
"<define class="volume_level" classdeck="left" action="deck 1 effect_slider 'volume' 1" rightclick="temporary" orientation="vertical">"
and
"<define class="volume_level" classdeck="right" action="deck 1 effect_slider 'volume' 1" rightclick="temporary" orientation="vertical">"
The 4 deck skin uses these defines and actions.
"<define class="txt_OSDHC_DeckOn" visibility="leftdeck" classdeck="1" >
<pos x="+2" y="+58"/>
<size width="30" height="24"/>
<text size="30" color="#008ce1" weight="bold" scroll="no" align="center" action="get_deck"/>"
Repeat for the other 3 decks changing the "classdeck" number accordingly.
Then the defined actions for each deck for the skin.
"</define>
<define class="cmp_VolumeFader" classdeck="1">
<panel id="vol_linear" group="fadercurve" visible="levelfader_curve & param_smaller 0.35 ? on : off">
<pos x="+0" y="+5"/>
<size width="15" height="122"/>
<down x="735" y="2405"/>
</panel>
<panel id="vol_quad" group="fadercurve" visible="levelfader_curve & param_greater 0.34 ? param_smaller 0.80 ? on : off">
<down x="735+15" y="2405"/>
</panel>
<panel id="vol_exp" group="fadercurve" visible="levelfader_curve & param_greater 0.79 ? on : off">
<down x="735+30" y="2405"/>
</panel>
<slider action="level" orientation="vertical" dblclick="level 75%" rightclick="temporary" >
<pos x="+7" y="+0"/>
<size width="23" height="135"/>
<up x="825" y="2405"/>
<selected x="825" y="2405"/>
<fader>
<size width="23" height="15"/>
<pos x="1585" y="1400"/>
<mouserect x="+0" y="+0" width="21" height="12"/>
<tooltip />
</fader>
<tooltip />
</slider>
</define>
<define class="cmp_VolumeFader" classdeck="3">
</panel>
</panel>
</panel>
<fader>
<tooltip />
</fader>
<tooltip />
</slider>
</define>
<define class="cmp_VolumeFader" classdeck="left">
</panel>
</panel>
</panel>
<fader>
<tooltip />
</fader>
<tooltip />
</slider>
</define>
<define class="cmp_VolumeFader" classdeck="2">
<pos x="+15" y="+5"/>
<down x="780+30" y="2405"/>
</panel>
<down x="780+15" y="2405"/>
</panel>
<down x="780" y="2405"/>
</panel>
<pos x="+0" y="+0"/>
<fader>
<size width="23+2" height="15"/>
<pos x="1585-3" y="1400"/>
<tooltip />
</fader>
<tooltip />
</slider>
</define>
<define class="cmp_VolumeFader" classdeck="4">
</panel>
</panel>
</panel>
<fader>
<tooltip />
</fader>
<tooltip />
</slider>
</define>
<define class="cmp_VolumeFader" classdeck="right">
</panel>
</panel>
</panel>
<fader>
<tooltip />
</fader>
<tooltip />
</slider>"
The relevant parts are the "<slider action="level" orientation="vertical" dblclick="level 75%" rightclick="temporary" >" but changing the slider action="level" to "slider action="deck 1 slider_effect 'volume' 1" for any of those 6 places results in it operating both left and right sliders.
I want to have them work independently obviously.
I think, try change the action to
effect_active 'volume' ? effect_slider 'volume' 1 : level
Once again in back, lol! Ok hows everybody doing, hopefully lifes been good.
So has any head way been by either of us users or from the team??
Main issue I see is the no headphones but I have managed just fine.
Lets hear it fellas , lol!
Well I guess were gonna let this go???
I'm here wanting post fader FX as well!!!!
All that coding isn't for me....
I may need to take a trip to youtube....
Does VDJ8 allow post fader effects, and if so, how to activate them?
No post fader effects yet. Have a read of this thread.
Can I please get some help making this work with 4 decks??
Ice tried a few different things but ended up resetting everything.
Any help would be greatly appreciated.
locodog wrote :
@ anyone waiting for 4 decks I'll be posting a full how as a text file to download (it could be a couple of weeks) as the scripts are huge (too big for the forum char limit) and it's more than just a xfader script and a button script (the cross assign buttons need scripting too)
Did you ever get this text file done?? Im using a Mac so the only way is with this script.
sorry i saw the previous post and forgot to reply.
4 decks gets long, very long when you start considering xfader assign
it's 110,000 chars for the fader and 23,000 chars for the button, i'm not even sure the button is right anymore it's been a year since i even looked at it.
and i just don't have the time i used to.
i don't remember even stating the xfader assign buttons so they're still to do.
Man that's huge!!
Why wont Atomix just make this happen for us already, ugh.
Its cool bro, I didn't realize it was that much work. I'll just stick with the 2 decks.
Post fader effect ? Where ? Still missing ? Come on guys its really standard ...
BUILD 3342 (2016-07-30)
-Add option 'fxProcessing' to select pre- or post-fader effects
has anyone tried this??
