Hi,
I would be interested in a way to change the stars rate of a song using a keybord shortcut (a new verb maybe?)
thanks,
Kaléo.
thanks,
Kaléo.
Posted Fri 04 Sep 15 @ 8:49 pm
I would like to set browser tags with VDJ script, so I can map that actions to any key/controller button I want.
Something like: "set_tag_rating 4" to set rating 4 (stars) to the current track.
And maybe something like: "set_tag_genre 'House'" or "set_tag_user1 'Intro'" to set a tag value with a given string.
That would help immense when prelistening to tracks to sort and rate them.
Posted Fri 11 Sep 15 @ 11:39 am
I second this.
Maybe to ease the implementation create an action that takes 2 parameters.
set_tag 'rating' 4
set_tag 'genre' 'House'
set_tag 'rating' 4
Posted Fri 11 Sep 15 @ 1:50 pm
in the meantime use the colour setting and batch edit.
Posted Fri 11 Sep 15 @ 7:05 pm
I think you should elaborate that a bit further
I would but typing long texts on the mobile is a pain.
Posted Fri 11 Sep 15 @ 8:16 pm
You can set colours by script instantly you can also sort files by colour
So intended 1* songs mark red, 2* yellow whatever so on.
browsed_file_color "red"
when your done marking recurse the database
then right click the field headers and include colour
sort by colour
now you have all the 1 stars next to each other hi-lite them all and batch edit to 1 star and remove the colouring.
sort by colour
Posted Sun 13 Sep 15 @ 9:43 am
Hi,
My wish is to have the browser column header behave just as vdj 7, for example: Selecting and Sorting with a config windows of check boxes.
VDJ 7 browser is very very good, please keep the good things.
Thanks
Thanks
Posted Thu 01 Oct 15 @ 4:30 pm
Prelisten just exactly same as in VDJ 7 beneath the browser and horizontal side list sharing the browser's columns.
Thanks.
Default VDJ 7 skin for VDJ 8 request.
Thanks.
Posted Thu 01 Oct 15 @ 4:33 pm
The column spacing for the horizontal sidelist to match the spacing on the selected item in the directory tree.
It's not possible to adjust the spacing in the horizontal playlist AFAIK and it looks ugly.
Posted Mon 05 Oct 15 @ 6:52 pm
When I move the spacing of the folder columns, the sidelist columns move with it. Not sure how you got them that way.
Posted Tue 06 Oct 15 @ 5:04 am
Maybe your sidelist had some other spacing values (from a previous build).
Open settings.xml and delete the line <browserColumns>, then open VirtualDJ again.
EDIt.. hmm that may not work.. You will probably have to manually edit the values of the |side part
@Adion, this could be a bug here ? Shouldnt Sidelist get the same values if that line was deleted ? Does it read those values from another one ?
Posted Tue 06 Oct 15 @ 6:42 pm
I think the issue here is that if you change between a filter folder, history or playlist which can all have different column spacing (and contents), the horizontal sidelist at the bottom doesn't adjust to suit. It's also a bit off if the list above has a scollbar but the horizontal sidelist doesn't.
my settings.xml looks like this. Not sure which of these strings controls which part of the browser.
file=arti(37.21),titl(29.72),comm(18.87),year(5.11),bpm(3.97),leng(5.11)|
side=arti(24.53),titl(24.49),comm(23.39),bpm(7.51),year(8.72),leng(11.36)|
side(sbnk)=spla(10),titl(60),svol(30)|side(auto)=arti(35.22),titl(34.59),year(9.64),bpm(8.79),leng(11.76)|
side(kara)=titl(40),arti(40),sing(20)|file(hist)=arti(30.45),titl(29.75),comm(25.9),year(5.16),bpm(3.5),plti(5.25)|
file(play)=arti(33.46),titl(33.86),comm(19.79),year(4.24),bpm(3.53),leng(5.12)|
file(samp)=spla(4),spos(4),titl(88),sedi(4)|file(sbnk)=spla(4),spos(4),titl(40),sgrp(20),svol(16),slen(12),sedi(4)|
file(auto)=titl(30),arti(30),mix(20),leng(10),plat(10)|spec=titl(30),arti(30),mix(20),leng(10),bpm(10)|
file(kara)=titl(40),arti(40),sing(20)
Posted Tue 06 Oct 15 @ 7:34 pm
Try the first 2 lines having the same values. So this...
should be ..
side=arti(37.21),titl(29.72),comm(18.87),year(5.11),bpm(3.97),leng(5.11)|
should be ..
Posted Tue 06 Oct 15 @ 9:13 pm
Hi Babis,
I have managed to get everything to match now.
Specific issue seems to be that you can set completely separate columns for folders, playlist and history.
If you decide to change either the playlist or history column selection or sizing it throws out the horizontal playlist.
Maybe it should also have settings to match playlist or history if selected.
Keith
Keith
Posted Wed 07 Oct 15 @ 3:11 pm
Display on external Monitor of current Automix song info and upcoming songs
I posted this on "Scripts you'd like to see forum" but then I thought this might
be implemented only at a program level so, not knowing who monitors which
forums, I am posting it here also. Maybe other DJ's could chime in and give their
opinions of the usefulness of this feature.
Professional dancers like to know:
1) What is currently playing;
2) What is coming up next,
3) Information about the songs.
Besides Title and Artist, dancers like to know genre, BPM, and other
information the DJ may deem important. The Option of displaying an
additional NOTES field would handle all of this ... example:
Currently Playing: Billie Jean - Michael Jackson - 118bpm - Contemporary West Coast Swing
Coming Up: Cool Cat {EXP mix} - 116bpm Foxtrot/West Coast Swing
Coming Up: Conga Jam - Dura [Dj Good Sho] 184bpm Salsa
... you get the idea.
Posted Wed 07 Oct 15 @ 5:07 pm
This thread is specifically for requests relating to the Browser element of Virtual DJ.
Please post your request here:
http://www.virtualdj.com/forums/188628/Wishes_and_new_features/_Ver_8__Video_-_Wishes_and_new_features.html
Posted Fri 09 Oct 15 @ 9:30 pm
Do you want me to summarise the above information regarding the horizontal sidelist column spacing in a new thread in the bug forum?
Doesn't seem to be getting any response here?
Keith
Keith
Posted Sun 11 Oct 15 @ 5:40 pm
The problem is that I don't think the sidelist should follow the columns selected for history or sampler for example, so there will always be cases where the columns are not identical and thus not aligned.
Posted Mon 12 Oct 15 @ 5:33 am
Hi Guys,
Would it be possible for you to install a button on VDJ 8that can give access to a full pager browser in order that more songs can be visible on screen, this is a feature that was implemented on VDJ 7 and I use very often.
Posted Mon 12 Oct 15 @ 7:19 am
It's just missing from the skin. There are lots of skins with this built in. Why it was missed and sill isn't present in the default skin no one knows......
Posted Mon 12 Oct 15 @ 8:24 am
