G4v control does not work whit virtual dj 8 I try everything and it does not work please help. I need the mappers for this version tanks
Posted Wed 21 May 14 @ 11:22 pm
the Gemini G4 is natively supported and no mapping files are required.
Are you on a windows or Mac OS computer ? have you tried to delete the settings.xml file from Documents/VirtualDJ folder and relaunch ? you have absolutely no control of the software (sliders dont move on screen if u move from the device ) ?
Please provide us the following...
1. Screenshot of the CONTROLLERs tab of VirtualDJ 8 Config
2. From Config-->OPTIONS tab of VirtualDJ, enable the ShowAdvanced Options and search for the setting createMidiLog. Set it to yes. Close VirtualDj, make sure the unit is connected and launch again. Close VirtualDJ and post here the content of the Log Report.txt file you will find in Documents/virtualDJ folder.
Posted Wed 21 May 14 @ 11:37 pm
Here is the log report.
Audio device found: name="Speakers and Headphones (IDT High Definition Audio CODEC)" vid="0x111D" pid="0x7605" mid="0x0000"
Audio device found: name="Communications Headphones (IDT High Definition Audio CODEC)" vid="0x111D" pid="0x7605" mid="0x0000"
Audio device found: name="G4V Audio" vid="0x23C7" pid="0x0465" mid="0x0000"
Audio device found: input name="Integrated Microphone Array (IDT High Definition Audio CODEC)" vid="0x111D" pid="0x7605" mid="0x0000"
Audio device found: input name="External Mic (IDT High Definition Audio CODEC)" vid="0x111D" pid="0x7605" mid="0x0000"
Audio device found: asio="Gemini ASIO" mid="0x0000"
Midi out device detected, name:Microsoft GS Wavetable Synth mid:1 pid:27
MIDI Device Identifying: \\?\usb#vid_23c7&pid_0465&mi_02#6&1840d6fb&0&0002#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\global (in:0 out:1)
MIDI Device Identified by PID/VID: \\?\usb#vid_23c7&pid_0465&mi_02#6&1840d6fb&0&0002#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\global
MIDI Device Identifying: Microsoft GS Wavetable Synth (in:-1 out:0)
MIDI Device Not Identified: Microsoft GS Wavetable Synth
Posted Fri 23 May 14 @ 12:23 am
I found the problem had to put yes to disablebuiltin definitions and it works thanks anyway
Posted Fri 23 May 14 @ 1:46 am
The G4V is natively supported but I miss two important features which are seek and got to the beginning of the track (0:00).
Is there a way to include this maybe seek with the jog and shift?
Posted Sun 27 Mar 16 @ 10:09 pm
