Not sure, but filter_activate sounds wrong.
Have you tried
That should reset the filter.
Have you tried
deck 1 filter 50% & deck 2 filter 50%
Posted Thu 26 Jun 14 @ 2:31 am
try with
& deck 1 filter_activate off & deck 2 filter_activate off
Posted Thu 26 Jun 14 @ 4:26 am
didn't work, button still lit up and on
Have you tried
Have you tried
Posted Thu 26 Jun 14 @ 6:57 am
moramax wrote :
try with
Posted Thu 26 Jun 14 @ 6:58 am
I have the same on the mixtrack pro. One side sounds more crispy. Louder.
Posted Thu 26 Jun 14 @ 8:46 am
Remove the mapping for the filter. Just erase it. Set them at unity and you never have the issue again.
Posted Thu 26 Jun 14 @ 9:17 am
I know this happens on 7, not sure what I did for 8.
Posted Thu 26 Jun 14 @ 11:04 am
@TulsaDJ
tested here, it works perfect...the filter is switched off when Virtualdj is started.
most likely there is something wrong in your mapper.
please, open a ticket where we can organize to check your mapper.
http://www.virtualdj.com/contact/step2.html
Posted Thu 26 Jun 14 @ 1:44 pm
