It's in the list of compatible devices, and the audio configures absolutely fine, I'm having a difficulty with the mapping/controlling the software side of things with my N4.
Any suggestions?
Any suggestions?
Posted Mon 12 May 14 @ 12:14 pm
Mac?
Posted Mon 12 May 14 @ 12:16 pm
Yea, macbook pro. Works absolutely fine on VDJ Pro 7?
thanks
thanks
Posted Mon 12 May 14 @ 12:50 pm
There are some issues with controller recognition in V8 - hence this Pre-release version first.
It is being looked at - the dev team will fix it.
Posted Mon 12 May 14 @ 12:55 pm
Ah right ok, I have no other issues at all so far, so all is good! One more question, refreshing cache authorisations with ContentUnlimited on VDJ8?
Posted Mon 12 May 14 @ 1:04 pm
Automatic when you load the software and have an internet connection.
Posted Mon 12 May 14 @ 1:05 pm
Hello Dan,
Any chance about the time frame when controllers will auto-detect in 8?
Posted Mon 12 May 14 @ 1:08 pm
Not at the moment.
Posted Mon 12 May 14 @ 1:09 pm
djtouchdan wrote :
Not at the moment.
Thank you :)
Posted Mon 12 May 14 @ 1:10 pm
Ok cool, so say I setup at a venue with no WIFI, I would ideally have to load up the software before I got there, correct? Or does it only refresh authorisation every month?
Posted Mon 12 May 14 @ 1:16 pm
About the DRM authorization, nothing is really changed in version 8. You still have to connect your computer to the Internet to do that. Each file has a different expired date (30 days after download), so you need to do that quite often to make sure all your files are refreshed. However, we added in version 8, a pop-up message on launch that will warn you if some files are about to expire, and you will see a special subfolder in the content Unlimited folder with these files.
Ps. Please dont hijack threads. This one is related to some detection issues we have on Mac side for Numark N4.
thank you
thank you
Posted Mon 12 May 14 @ 1:47 pm
